UP for sale or swap is my RX7
FOR SALE / SWAP : FC RX7 WITH 300 + RWKW
Engine & Exhaust
13B Bridge Port Turbo, Series 5 Block, Freshly Rebuilt with new SCR 2mm unbreakable seals less than 3500km ago, (its still in run in tune) Solid corner seals, all gaskets and oil seals have been replaced, dowelled, window bearings and stationary gear have been modified to suit, custom made exhaust manifold - heat treaded, T70 turbo kit, earls fittings and braided hoses, turbo beanie bag, 60mm external wastegate, custom heat treated 3.5' exhaust from turbo straight through to hks cannon.
custom hks front mount with custom stainless 3' polished piping, greddy style rs blow off valve, all stainless clamps and 3 ply ss performance silicon joiners, custom made alloy cooler hat, custom polished stainless intake pipe with blitz LM mesh pod filter.
Polished upper manifold and water filler neck, brand new engine mounts, twin belt alternator pulley, brand new break master fitted.
Cooling
PWR alloy radiator, spal 16' thermo fan, all new hoses and clamps, brand new water pump.
Engine Managment
Microtec LT10S, Microtec 4 line hand controller, custom wired and mounted in glovebox with individual switches for fuel pump and ignition, 4 BOSCH ignition coils custom mounted in engine bay with 8.8mm topgun leads, custom bracket for hand controller.
Fuel System
Bosch 700hp intank fuel pump with earls fittings and braided hose, sard fuel pressure regulator, 398cc primary injectors, 1600cc secondary injectors, custom fuel rails to suit these injectors, new bosch injector plugs, new bosch fuel filter, New fuel lines
Driveline
6 Puck button extreme motorsport clutch with 1400kg clamping pressure plate, extreme molly lighten flywheel (6kg), standard 5 speed gear box with new oil, very tight LSD.
Suspension
Tein damper adjustable suspension with lowered springs all round, front and rear strut braces.
Body
Fresh respray in Majestic orange, GP sports body kit, series 5 rear tail lights, crystal blue head lights, custom aero mirrors.
Wheels and Tyres
17' Stern 3 piece light jap rims, bridgestone 235/45/r17 teo1's on the front, bridgestone 265/45/r17 te01's on the rear, rear have 25mm bolt on alloy spacers, front have extended wheel studs with 8mm spacers.
Interior
OBX bucket seats, 3 point racing harnesses, speco boost guage, isotta sports steering wheel, blitz alloy gear knob, new power window switches, razo alloy racing pedals, drift handbrake button.
Sound System
Sony Competition Deck, pioneer 4' front splits, 6'5 JBL rear speakers, 650 watt rms monoblock amp, 600 watt rms 4 channel amp, 2 x 12' JBL dual voice coil subs (600watts rms each), DLS wiring and connectors, subs and amps are mounted in custom setup.
Electrical
Battery has been relocated to boot, isolation switch installed also in boot, brand new orbital 750cca battery.
ITEM CONDITION : Good
PICTURES : YES
PRICE : $ 17500 ONO NOW $ 16500 !!!!
CONTACT : MATTHEW
mobile number : 0433549430
Edited by stylz7
https://www.sau.com.au/forums/topic/211865-for-sale-swap-fc-rx7-with-300rwkw/
  • 3 weeks later...
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
