Hey I have a rb25det which is out of a stagea which is all wheel drive and the original sump incorporates the front diff however i want to put this engine in my cefiro. I have a normal rear wheel drive sump and it is not quite as wide and also the oil pick up is in a different spot (not by much though) does anyone know where i could get myn modified or a custom one made up if need be?? Thanks
where are you located? might help people to suggest workshops local to you that could help you out.
Sumps arent too difficult to modify, but can be pricey,
show us a pic of the sump you have, you might be able to get it welded up to remove the front shafts like is done with the GTR sumps
u better make sure they remove the front diff aswell, no point in keeping it
mind pm'ing me the price u got? i got a spare rb20det off a gts4 i cud use as a spare
Edited by Dan_J
just an update got my sump back, dummy fit the engine in and the front of the sump only JUST touchs the front sway bar, so goin to do a bit of grinding and she should be all good, its a tight squeeze all round but.
    • Hope your all having a mean Xmas! If anyone happens to know any trick to using the insanely complex climate control system, I cannot get it to not be on dual zone no matter how many times I deselect it (will say it's not but both vents blow different temps). Also one side is always hot, one always cold 🤷
    • I'd be looking at the mentioned EFR kit, room to turn it up if decide on e85 (which we know you will) and be super responsive and fun on the street. OR https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/?srsltid=AfmBOorrJa2S76JR5ekXprxBOtU44a1UProbe64YaiVi9zTVp1Lj814w And add whooshy noise for extra fun C5 corvette prices are coming down locally here and a mate has a manual one and is a heap of fun on the street and track.
    • I have an Elite 2500, honestly most of this has been a lot of smaller tasks chasing little details and a whole lot of life getting in the way of bigger projects. I don't mind too much looking at a spectrograph vs having audio knock ears.
    • Nah nah nah nah. Don't do it. It's not all about the full throttle power delivery. The main "street fun" and drivability gains from smaller rear (in this case) is how you will have boost available from a low rpm when yo just roll onto the throttle. Think jinking in and out of traffic, coming out of roundabouts, etc etc, where you just want to roll onto the throttle a little and have the spooly noise from ~2000rpm and a swell of torque. More of what you've already achieved by going to 2.5. And then, towards the tail end of 2025 you can pull the turbo 4 out and put in a V8 like we originally suggested. :P
