hey guys! :)
i have a skyline R30 and it seem's the fuel pump is buggered on it it makes a clicking noise and thats about it....now i've rang bursons's which i knew would be expensive for a new one it'll be $475 :| no way am i paying that so was wondering what should i try now wrecker's or is there another kind of fuel pump that works?
any help more then appreciated
https://www.sau.com.au/forums/topic/211895-fuel-pump-for-a-r30/
ebay new R30 fuel pump $299
it is a bit exxy.....
i am positive a bosch item would be cheaper....
bosh pump $140 melb
or
$180 ext pump (sydney)
if you get one from the wreckers youre probably gonna have the same problem later on... but if its just to get the car running or to the car yard, then a wrecker one woudl be fine (vl commodore uses external one, should be perfect)
I just had a whole lot of trouble with my fuel pump. Turnrd out to be a faulty earth connection. I had pump in and out three times (bugger of a job) It was Ghostrider suggested the earth bit, and hey presto she worked again.
If you need another pump, suggest a VL, will be much easier? and cheaper.
Before installing set up and run to make sure it is wired up the right way.
Edited by 66yostagea
yea im using a vl pump bosch 070 i think they r. deff fair bit larger cos vlts run the same pump and can get bout 180rwkw outa them b4 maxing (rb30et). goes in easy. all have 2 do is run a longer fuel hose from the fuel pump outlet to the steel fuel line and change the plug over.
$0 from local wreckers :laugh:
Edited by OUTATIME
I got a vl turbo pump that works last time it was in the car, and a r30 fuel pump that was only on my car for a couple years.
You can have either one for $50.
If you're interested ill test them out, make sure they still switch on and pump.
They are both bosch.
Edited by skybt1
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
