What Oil Pump
craked
 Share
That much power, probably an aftermarket, but as a drag car avoid the N1 which is known to be a bit brittle.
Otherwise grab a standard R33/34 pump and maybe up the spring for the pressure relief valve. What pressures do drag cars with that sort of HP need is the first question to answer.
You will need an oil pump from one of the DOHC motors or a VL Turbo pump at the least. My engine which was built by a supposedly reputable workshop who shall remain nameless supplied me with an RB30E oil pump after repeatedly assuring me it will be ok. It will not work as it flows much less oil. I found out the hard way... Refer to pictures:
RB30E Pump:
RB26DETT Pump:
Keep in mind that if using another pump such as a Tomei or JUN or plan on track work you should carry out the relevant oil control modifications.
4 stage dry sump pump.
2 pickup points from the pan and one from the rear of the head.
+1
only real setup your gonna have a win with im afraid
also make sure your pump is capable of pumping your oil from the rear of the car (if your tank is mounted there) or make room in the engine bay for it
+1
Hows the pricing though?
Looks like a lot of hybrid owners are going for tomei and jun pumps :)
talking about dry sumps and oil pumps, my machine shop have designed their own dry sump pumps that they use on their 7sec drag bikes, and i'm currently working with them to design a package to be used with the rb's. we are also looking at a billet oil pump with an external pressure relief
yeh if they are building a 900hp drag motor, which realisticly would cost 25k+ a 5-7k dry sump setup would be peanuts
Say the motor costs 25k, and the dry sump is 5k, thats 20% - i wouldnt call a 20% difference peanuts :ninja:
He may be trying to do it on the cheap (which i know, i know, wont last etc)
Say the motor costs 25k, and the dry sump is 5k, thats 20% - i wouldnt call a 20% difference peanuts :D
peasnuts wasnt the best of words that i coulda used huh :ninja: but i spose u get where im coming from?
Yep, there are a few drag RB30's that use them too. Birrong Automotive did one using a Peterson pump. You might be able to give them a buzz. It's on a red VL turbo which is doing a 8.6 I think. Shame you don't wanna go dry sump. You would never have to worry about oil problems with one but I cna understand that you might want to spend money elsewhere.
I'm also building a 1000hp 30/26 and using a jun pump. Would have love to have used a full dry sump setup but you have to stop somewhere. We will just have to see how it goes I guess. I dont think it is as much of an issue on a drag car as it is on a circuit car especially with a 30 bottom end with the rpm kept down. I have fitted a vacuum pump to this to help keep blow by to a minimum. I'm also building a pretty wild sr20 and would have loved to have done a drysump like the one in the pic. post-19687-1206961801_thumb.jpg
Edited by datsqik
 Share
    • I have S15 helical too. It is a bit worn. I think the drive behaviour you describe is related to this wear. Wear of helicals is something that no-one seems to have paid a lot of attention to, but now that they (as in original Nissan ones) are all a bit old - we're starting to  see the consequences. The ends of the helical spurs wear into the casing. That's where they perform the braking that diverts torque. Some of the more modern helical designs have proper wear surfaces introduced there, but the Nissan ones are just steel on steel (or iron).
    • I've had a range of rear diff centres - open, viscous, helical, mechanical, welded, etc.   I can't go past a refreshed factory 32 gtr centre for consistent lock and street driving. The next step up for me would be the nismo 1.5 way , which likely suits you better as track sounds like the focus. Will chatter in carparks but its not the worst.   I have never tried a quaife rear diff, an option I've looked at before and might be one for you .....   Currently playing with an S15 centre at the moment and I hate it.  The transition from single wheel spin either side is just weird.
    • Honestly, I did think the PDM could do it and thought Haltech told me the pump didn’t like it. But after re-reading the emails and comments above, I clearly misunderstood lol.
    • I also run a CD009. I'm currently on a 4.08 and it's not great. I originally intended to run a 3.3 but had issues, more on that later. I'd stick to anywhere between a 3.3-3.7 as found in the 350z.  As for brands of ring and pinions, absolutely stay away from Speedtek. They are absolute garbage. See my build thread for more information on that. I went through two of there 3.3's and both had bad runout. They were paperweights and they have still yet to refund me.  I ended up putting in a Nissan 4.08, which was better then the original 4.36 but is far from ideal. I'm going to pop a 3.5 in this winter. I'd stick Nissan. I've also heard of a company "Neat Gearboxes" that makes them. Haven't tried them, but they can't be worst then Speedtek...
    • You should Nistune the ECU, so you have freedom to use modern injectors instead of replacing with the same old shit. This is also required if you want to boost it up above ~200rwkW, where the stock injectors will be running out of capacity. Having said that, it is unlikely that the injectors need replacing just 'coz. If you imported it from Japan, the fuel should have been pretty good quality for the whole life of the car.
