Hi all,
During a recent move i have misplaced all my bellhousing and gearbox crossmember bolts.
Just wondering if anyone can measure up or know exactly the bolts that i require so i can go down and get some from my local fastener store.
I need all the bolts and nuts sizes, dimensions etc.
Much needed help as i want to put my baby back together.
Cheers,
Gordo.
!By the way i have an RB25det R33 manual!
Edited by AlpineFreak
https://www.sau.com.au/forums/topic/211969-lost-bolts-for-bellhousing/
There are different sizes in different parts of the bell housing. Measure the thickness of the bell housing at each bolt hole, then add about 15mm - that should give you the length required.
From memory, I think the larger bolts are 12x1.25 (maybe 1.5). The smaller will probably be 8x1 .
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
