got this today. colour is irrelevant - look at the right side.
prefer 5spd auto at this stage though if there is a 6 spd lying around I'd take that. I'll need it for a few days.
also needs to be a 3.5 Lt version.
donors? :thumbsup:
https://www.sau.com.au/forums/topic/212055-need-a-mule/
thats waht I intend to prove. on the last 6sp one I had it wasn't but it WAS listed. if its a case of 3-4 pins in appropriate spots and two lights then it will be released as a kit..
it WILL NOT cover a GT8 CVT. have one at hand currently and its VERY different.
https://www.sau.com.au/forums/topic/212055-need-a-mule/#findComment-3747955
couple of days. yours would be ideal. the pearl one I had here for ages was the other one I was going to pull down. fix the vette and give me a date. form there I'll allocate. that timeframe is fine with me and allows me to get some other stuff out of the way.
I'll probably put 150km on the car in testing it if it works the way I want.
time wise next week is fine. I have a 35 due (april 5th.) in at isaso that I'll have to do as well. yours will time in well with that.
https://www.sau.com.au/forums/topic/212055-need-a-mule/#findComment-3747984
well i can get a new battery for the american junk this weekend, and could, say get the car to you sunday night for you to have for mon/tues? maybe wed?
maybe you can do the image button also in that time? :cheers:
let me know if that suits...
very very very small chance that when i get my timetable tomorrow it won't work but that's a 0.001% chance
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/212055-need-a-mule/#findComment-3748011
Interesting.... Hope you can provide a guide for this in the future Chris, especially for those of us unfortunate enough to live on the other side of the ditch where we can't send our cars to ya...
On a related note, any idea if cars without the audio controls on the wheel are still wired for them? My poverty-pack 250GTm doesn't have the audio controls, was wondering how hard it would be add them if I can get the button set for the wheel... Though the idea of rooting around near the airbag doesn't hold much appeal!
Edited by Ant
https://www.sau.com.au/forums/topic/212055-need-a-mule/#findComment-3748034
maybe you can do the image button also in that time? :D
that was my intent. I have a 500 SL benz that I need to tackle as well now. he just popped by and asked me to look at it..
once I prove it - yes. to answer your second question- pull the shroud off and count the wires on your clockspring. if you have 1 only - no - if you have several then yes. I'll take a snap of waz's one when I get the car. I know its not wired for cruise but does haev controls.
Is that steering wheel from a 02 - on Stagea?
As they came with cruise yeah.
nope. G35. 11/03 VQ25DET had cruise. worked on one of those already. this only applies to the VQ35 though.
https://www.sau.com.au/forums/topic/212055-need-a-mule/#findComment-3748560
just for efveryone's reference, the only cruise that was offered on the V35 was the active cruise in the sedans
i posted a pic in another thread.. will attach it again.. the car has an IR display on the front grille and has different lights in the instrument cluster..
the cruise from the G35 is a normal cruise system from what i have read on G35driver
http://www.skylinesaustralia.com/forums/in...t&id=151333
http://www.skylinesaustralia.com/forums/in...t&id=151334
https://www.sau.com.au/forums/topic/212055-need-a-mule/#findComment-3748647
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
