Hi guys
When i get up into boost the car cuts out. I have read in Hot 4's that r34 have problems with a boost cut. Do I need to upgrade the fuel pump or is there there something else that i need to do to the car? I have a SAFC2 and i should be getting a tune soon to 10psi should i fix this problem before i get it tuned?
https://www.sau.com.au/forums/topic/212061-r34-fuel-cut/
what do you mean by cuts out? what RPM does it happen at? does it kind of hang at lik 4500rpm? check your coilpacks and spark plug gap. If the safc isnt tuned already tuning it could just mask the problem.
https://www.sau.com.au/forums/topic/212061-r34-fuel-cut/#findComment-3746909
It happens around 4500 - 5000rpm, the engine sorter stops for a split second like if there was no fuel, it only happens when i am in high boost like 7psi +, how much money am i looking at if i need to get the coilpacks replaced? so this problem may not have anyhthing to do with the fuel pump?
https://www.sau.com.au/forums/topic/212061-r34-fuel-cut/#findComment-3747308
sounds like coil issue. You can do it yourself, the coils are 485 delivered from this forum not that hard to replace. There wont be a problem with your fuel pump if it is the coils at fault.
Edited by phenline
https://www.sau.com.au/forums/topic/212061-r34-fuel-cut/#findComment-3747524
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
