Take it down to a data recovery company immediately... $270 is a reasonable price for the work involved. Do not try recovery software or touch the drive.. you could be making subsequent recovery more difficult if you try. If your documents mean anything to you, get an expert to look at it.
I know of a few places in Adelaide that do recovery, just pm me if you want more info.
$270 is a shit price for a piece of hardware that still works, it just wiped the header files... the HDD isn't broken...
If it's a bad header.. that's a crap price... if it's a crashed hardie then i've seen worse prices than $270. But seriously, if the data is that important, e.g. you have your 4 years thesis on it or something without a backup, then it's not much to pay.
Me? Nope. I work with pretty critical data though, defence / health records etc... if it's a screwed ntfs header we just fix that using a hex editor, if the drive sounds like it's crashed, we usually send it to the experts. If we try formatting it, or reading off the crash drive, it could make things a lot more difficult to recover for the data specialists, so we tend to leave it alone.
The reason that the pro data recovery cost so much money is that they dismantle the hard drive, buy a new hard drive exactly the same, and then transplant the platter into the new drive to read the data. This needs to be done in an absolutely clean environment too. Most of the bigger data recovery places have a full on anti-dust clean room. This all costs money! :O
Did you get it fixeded up yet?
doof, your not on my msn cos you don't put out! pm'ed ya.
No.. Some genius switched the details over on the phone and internet company.. = no internet for me..
Dude.. You are posting in the NSW forums.. You have to be kidding right..
Agreed.. I'm not paying
The reason that the pro data recovery cost so much money is that they dismantle the hard drive, buy a new hard drive exactly the same, and then transplant the platter into the new drive to read the data. This needs to be done in an absolutely clean environment too. Most of the bigger data recovery places have a full on anti-dust clean room. This all costs money! :)
Correct.. I'm very sterile too! :O
zackly :ermm: I went to a really good one of those once... was static and dust free and the workers had to wear air tight suits :O Their prices for what they charged were astronomical too! I got a quote to just change the motor on the HDD and it was over $500... Me thinks they work mostly for businesses, not little people like me...
Either way Dif, if you turned it on to find there was nothing there, that means the hardware is fine and you are only missing the header files... a software program will be able to sort that out and get most, if not all, of your files back :huh:
zackly ;) I went to a really good one of those once... was static and dust free and the workers had to wear air tight suits :P Their prices for what they charged were astronomical too! I got a quote to just change the motor on the HDD and it was over $500... Me thinks they work mostly for businesses, not little people like me...
Either way Dif, if you turned it on to find there was nothing there, that means the hardware is fine and you are only missing the header files... a software program will be able to sort that out and get most, if not all, of your files back :)
Yep It all works.. Just need to recover shit..
I'm pissed that our net is down.. and some f**k stole my memory stick so I cant download any programs.. GRRR..
The reason that the pro data recovery cost so much money is that they dismantle the hard drive, buy a new hard drive exactly the same, and then transplant the platter into the new drive to read the data. This needs to be done in an absolutely clean environment too. Most of the bigger data recovery places have a full on anti-dust clean room. This all costs money! :P
Yep Primordial's right... has to be a hermetically sealed area. Oh well, if your data is priceless then that'd be your best bet.
Easy there son, just trying to help a brother out here.
I know but why would I send it to Adelaide..
It's not hardware problems it's software problems..
I'm not going to pay someone $270 to recover data when I can either do it myself or have people I know do it even cheaper.
If you don't do everything perfect, you might be in a worse situation than you are now.
I can see exactly where Howie is coming from - if the data is *that* criticial to you, don't play around trying to get it back with a free application. If it's stuff you can afford to lose if you totally stuff up, then go for gold :P
Edited by TommO
You're assuming it's not hardware... the reason I suggested Adelaide, was because I use a group who deal primarily with restoring data for the DoD and the higher education sector.. i've used them plenty of times and I trust them. They aren't backyarders, the owner holds a doctorate in computer systems engineering.
Exactly... if the data isn't *that* critical, then go your hardest... even try swapping the platter over to a replacement hard drive if you want.
If it is software, then you're laughing then aren't you ;)
pretty certain it's software, being that it turns on and shit...
IF it somehow turns out to be hardware, then yes, it will cost a lot of money, and you should leave it to the pros... BUT IT'S NOT! FOCUS PEOPLE!
I've used data recovery services twice in the last 15 years and am very happy.
If the data is important why would you bollocks around with it and possibly change it from simple to recover to impossible to recover.
On the other hand, if you can afford to lose it, go for it!
How'd you go Corrinne? Shouldn't be too hard to recover..
They're just going to do the same thing.. Deleted files only become hard to recover when you overwrite them and the pointers in the MFT/FAT/WHATEVER get changed.. Anyways, really depends on how much you value what's on there!
in the meantime - my 320G drive has suffered mechanical failure - quote from Seagate to restore it - $900-$1700 - price of my gearbox repairs.. yet to work out what i'll do.. Anyone got someone to recommend
    • Yeah kids certainly add a whole another dimension to your life.  Life ceases to be about you and more about them for a while!  And I wouldn't have it any other way.  I love watching them play sport and make new friends along the way. Wow, sounds like your mate is a good guy to know!!!  He's got some serious toys in the toy box!  Yes it would be lovely to be able to do stuff to your car without getting all tied up in boring shit like how to pay for it!!  I would describe my spending style as "aggressively spontaneous and logical but regrettable purchasing"....  That will hopefully make no sense at all which would be appropriate given that is how I buy stuff.  I'll decide at the drop of a hat that I'm buying something expensive, research the living shit out of it for 2 days straight then go out and buy it.  Then I'll have instant buyers remorse for 2 days which generally passes by the time it turns up on the front step!  If I'm feeling ballsy sometimes I'll tell my wife.  Other times it just makes its way silently passed the house and out the back to the shed, never to be spoken of again...
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
