It just doesn't meet ADR. You will get your car with a normal H1 globe. No escape.
You're not searching hard enough as there is already a thread about xenon headlights on the V-Series Skyline forum section.
which one?
I also searched the forums and got serveral threads.
but the reason why the bulbs were removed wasn't mentioned at all.
Unfortunately these are some of the pitfall that will happen to you when importing an Import yourself under SEVS...
Edit: In exception if you live in japan for 12 months or more and owning the car there, you may bring it in as personal import scheme and you may get away with not having to convert the HID lights - just the basic RWC - but I am not 100% of the rules - they change the rule all the time.
Haven't given it a total comparison but according to some people the headlights in 350GT didn't perform as well after being converted to H1, compared to original xenons. Regardless when this will deteoriate the headlights' performance, the law just don't care about it and the xenons need to be removed anyhow.
If your manage to get your original HID ballast, you will have to reinstall the xenons again with risking the car deemed as unroadworthy for registration. This is a pain in the bum job as most cases you need to remove the bumper to get access to the light, or put the car on jack and remove the rims & inner wheel guard to get access. Either way it's not gonna be easy peasy.
If not then the HID ballast would have been destroyed during compliance, and you'll be left with an option to either hunt the original ballast from local Nissan dealers (who may not be interested in sourcing the part for you at all), or buy an aftermarket HID kit from China/Hong Kong which sometimes creates more problems than glory. My bro in law's WRX has one of those chinese HID kit, and now he must turn his headlight on high beam all the times or the HID will flicker like a christmas tree light on steroids. So now he only have his high beams aimed low enough to become like a normal low beam and no 'higher' high beams. Pretty crap.
I'm sticking with my H1 globe at the moment, cbf bothered to swap it for now. And before anyone ask - no I will not sell my original ballast - I'm keeping them.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
