hey guys,
my stock sound system crackles when turned up. and it isn't even loud. so i'm keen to get some new speakers. not that keen to spend too much coin though. will this fix the problem?
i know bugger all about car sterios but i'm ok with tools and will be doing the install myself so any help would be awsome
if i do get new speakers should i get 6inch splits or are mid priced 6inch three ways ok.
also to install them do i just cut into the stock cable thats already there or do i re wire them.
i just want some clean crisp sound.
cheers :D
https://www.sau.com.au/forums/topic/212161-m35-sound-system/
they aren't that easy to replace and you will have to build new mounts for them
my stock standard speakers work fine and so I didn't put in my infinity kappa 62.5 i's as it would have been too much of a mission when the standard ones work well as it is
if you get stuck best to look for a good installer like I did and well pleased with him too does a sweet job of things
meh just replace them.
to reduce your cost just get the reccomended size that will fit your doors without major moding.
prob solved.
under 200 bucks and you can get some fitted + installed.
under 100 if you wanna be real dodgy
prob solved.
yeah i think i'll just get something that will fit with out to much modification. thanks
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
