  • Replies 54
Good luck with the buy, i have been looking meself for a n/a skyline r33 5 speed for awile for around $12000.
i Think i have found 1 trough a friend, but tradingpost and carpoint only have n/a for 14000 + to much if u ask me. Imports also want $14000.
if i get mine for $12000 i will send u the detials of my friend that works for a car company, he should be able to help you.
hi
ive still got the r33 S2 95-96 non turbo its in mint condition ill give u pics soon.
COMPLIENCED 3.4.03
its got a bodykit ,airbag,2 1/2 exhaust,MINI DISK,10 STACKER,POD AIR FILTER,ALARM/IMMOBILISER, AUTO,8 MONTHS REG, SXYSKY
GIVE ME A CALL ON 0421 891 877(OPTUS) TO NEG A PRICE
yeah Baileylsd rang you up he said u want around 16000, sorry to much atm for me, even though i plan to spend more than that doing one up, i want something unique.
But then agian your car could be what i am looking for so plz do get some pics and send them my way asap
[email protected]
or 0401286004 (optus prepaid)
by the way i am in melb....
cheers
If your willing to import it from Perth, there is one white Skyline for about $13k advertised. I am sure you could get it down to about $11k-$12k. I pass that yard every now and then, and he still has it after a few months.
He prolly want to get rid of it so i'd say he'll cut you a good deal.
Not sure what the condition is or turbo/NA. By the look of the standard tiny rims I would say a NA.
No affiliation whatsoever, just letting ya'll know :D
Munich
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
    • You need to buy a Saab Matt, ours had a button that turned all the dash lights off. Any decent aftermarket dash has sufficient brightness control and a headlight input for day/night settings. None of which probably helps OP
    • Yeah thanks...i thought it would be alot more i dont know 😄 I saw some videos on converting push/pull and it seems you need to "drill" the hole for slave(master) cylinder and buy some converter kit. On that front yoke clip i did not even know that is a thing and i need to source that(custom shops do not do that?) But anyway thank you for the info
    • Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
    • Would require a very smart body control module which these cars are about 20 years to old to have
