Hi all, Just have a quick question.
Just about to put some splits in the rear just need some advice on how to take the plastic panels that sit over the speakers out.
I have attempted to take them out, however seems like im damaging the plastic the more i try and pop them out.
Dosnt look like they are held in by any brackets. any help would be appriciated.
https://www.sau.com.au/forums/topic/212222-r34-rear-speakers/
i believe the rear seats and whole parcel shelf need to be removed to access without breaking them....i havent done my r34 as already had speakers changed over but have done a r33, the seats and parcel shelf need to be removed.
Edited by rgr34
yeah rgr34 is correct.
I had to take the back seats out first, then the rear parcel shelf came free.
Taking the seats out is easy.
For the seat itself look to the bottom left and right corners beneath the seat, two bolts have to be removed.
For the back rest, it is sitting on a hook from memory. You need to push the back rest up and out. It should come free.
I think you just pop the parcel shelf off from memory.
Good luck :O
Hey Darren...
It easy mate... dont take the plastic covers off.... install the speakers from under the shelf and keep a stelf look, and it saves you from removing the shelf, seats and side panels have to come off. I think the screws are still there mate.
Don't install splits in the rear, just do 2ways ok. Because splits are for front stage only.
Don't forget what I did for a job for 6 yrs bro.
Call me if ya need some help k
Llynden
P.S
Did I tell you there are 2 alarms in your car....lol
Just under the bonnet release there is a chrome switch flip it and then you can use the key alarm aswell.
Edited by Hotr34
Cheers for that lynden. Yeah I went to gold coast car sound the other day, and the homo's there said splits were the way to go. So I bought some matching dd-linears. :blink:
Yeah I was wondering what that was haha, however we ripped that out when putting the new alarm in.
Hey Darren...
Llynden
P.S
  • 3 weeks later...
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
