Hi all, Just have a quick question.
Just about to put some splits in the rear just need some advice on how to take the plastic panels that sit over the speakers out.
I have attempted to take them out, however seems like im damaging the plastic the more i try and pop them out.
Dosnt look like they are held in by any brackets. any help would be appriciated.
https://www.sau.com.au/forums/topic/212222-r34-rear-speakers/
i believe the rear seats and whole parcel shelf need to be removed to access without breaking them....i havent done my r34 as already had speakers changed over but have done a r33, the seats and parcel shelf need to be removed.
Edited by rgr34
yeah rgr34 is correct.
I had to take the back seats out first, then the rear parcel shelf came free.
Taking the seats out is easy.
For the seat itself look to the bottom left and right corners beneath the seat, two bolts have to be removed.
For the back rest, it is sitting on a hook from memory. You need to push the back rest up and out. It should come free.
I think you just pop the parcel shelf off from memory.
Good luck :O
Hey Darren...
It easy mate... dont take the plastic covers off.... install the speakers from under the shelf and keep a stelf look, and it saves you from removing the shelf, seats and side panels have to come off. I think the screws are still there mate.
Don't install splits in the rear, just do 2ways ok. Because splits are for front stage only.
Don't forget what I did for a job for 6 yrs bro.
Call me if ya need some help k
Llynden
P.S
Did I tell you there are 2 alarms in your car....lol
Just under the bonnet release there is a chrome switch flip it and then you can use the key alarm aswell.
Edited by Hotr34
Cheers for that lynden. Yeah I went to gold coast car sound the other day, and the homo's there said splits were the way to go. So I bought some matching dd-linears. :blink:
Yeah I was wondering what that was haha, however we ripped that out when putting the new alarm in.
Hey Darren...
Llynden
P.S
  • 3 weeks later...
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
