Hi guys, im new to this site. As topic states, installed a turbosmart boost controller now the car wont start! RB25, it had open hoses from the actuator and the pipe that leads to the blow off valve, it ran and was drivable. Fitted this now it barely starts, if it does it only runs for about 2 seconds then dies! Its sounds like its starving for air. Any advice on what it could be?? Thanx guys
Doesn't sound like the problem is the boost controller ... it wouldn't stop your engine completely like that. :pwned:
Try retracing your steps to see if anything else came loose or got affected.
I agree with everyone. Your car will start (but not boost properly) if the controller is on the wrong way. Your car WON'T start if a sensor is unplugged or a vacuum line isn't connected.
Check everything you worked on.
If you really belive its a turbosmart issue give them a call there allways more than happy to help as long as it was purchased through an approved workshop or store. If it was purchased through ebay then your out of luck as no tech support or warranty through ebay sales
Edited by Lorg
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
