Hey guys...
My car is due for a 5,000km service, I have the part numbers for the basic things I may require for your minor services, but I have one problem... I'm not sure who to take it to! I sort of rely on this car to get to work and at the moment I'm quite busy and need it to get around - this being said, does anyone know of someone I can take her to to get her service done as quickly as possible, even whilst I am there for a few hours if need be? An option is to drop it off in or around the Clayton/Mulgrave area where I work and can get a ride back to work with someone else and fetch it a few hours later, so this seems like a good idea... that or Saturday or evenings?
If someone has a contact, or would like to suggest someone or somewhere I would really really appreciate it.
And for tyres.. I have 17" 255's at the back, getting kinda flat - what suggestions might you have for decent tyres? I don't mind investing on the things that keep me stuck to the road :pwned:
Thank you!!
https://www.sau.com.au/forums/topic/212262-servicemaintenance-questions/
You checked the workshop thread right?
http://www.skylinesaustralia.com/forums/Lo...ops-t13305.html
There's a few around that really know skylines, not sure how quick they are though....
Oh, and look up the tyre thread in the handling section of the forum or search about tyres.
last time i chaged the oil in mine, it took 2 hours!!!! cause the oil filter just wouldnt come off... + i cant get my arms down there GGGRRRRRR!!!
then i invested in a oil cooler with oil filter relocation kit
I got a really good tool, takes no effort to get the filter off. $6 from super cheap.
Ease off the protein shakes big boy, then maybe your arms would fit down there LOL :D
I can see where nis0 is coming from though.
Another good reason to get it serviced somewhere is that you will have stamps/entries on your service books or at least receipts with not only everything done but more importantly the kms. When you sell the car in the future I can tell you this makes buyers feel a lot more secure seeing the gradual rise in kms on your 5k servicebooks over the years. Not knowing whether the low km car in front of you just had the dash swapped last year is a turn-off. You will definitely make more money this way than skimping on the $60 or w/e for each service.
For example I would be willing to pay at least a $2000 premium for a car with regular servicing and the documentation to prove it. That pays for probably 10 years worth of servicing every 5000kms, (I only drive 10,000k/year) not to mention how much money you will save in time (time=money for all of us), buying engine oil, and the remote possibility of missing something mechanically wrong that could endanger your engine and be a lot more costly in the end.
Cheers.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
