hey everyone,
looked under my radiator cap about 5 months after having installed a new alloy radiator, and the coolant has turned from a nice clean green to a dirty brown. the state of the coolant was quite poor (even worse) before i replaced the radiator, and at the time we only flushed the system with water. My mechanic said the rusty water might return until i flushed it thoroughly with one of those radiator flush cleaner things from supacheap.
so, now its time to do just that. i had a look at some threads via search, and also a copy of the manual i found on the internet.
before getting started, i just wanted to make sure I had everything I needed.
here's a list of things i'll need that i compiled from both the manual and various threads:
coolant (about 10L)
coolant flush
sealing agent to coat the cylinder block drain plug thread (referred to as: three bond 1386B in the manual.)
car jack/ramp. I'm thinking a trolley jack, will probably come in handy time and time again. anyone know how much a good one costs?
car stands to put under the car once raised
copper washer (to replace upon refitting) for the air release plug near intake plenum. (anyone know what size??)
plus things I already have:
socket set
basic tools, eg spanners, screw drivers, pocket knives etc etc.
as i'm a bit of a novice when it comes to working on my car, i'd really appreciate any tips or advice people can offer. i plan on taking photos and making a thorough DIY for this forum.
have i left anything out that i'll need?
and a few specific questions i have already. where exactly is the jacking point for the front of the car using a trolley jack? the picture in the manual is not too clear. also where is the block drain plug for the coolant? left or right side of block? i don't wanna confuse it with say... the oil plug and drain the wrong system!
ahhh sorry for the long winded thread. thanks for any help :pwned:
I'd say the Rb25 block is the same as the RB26 block so the drain plugs are on the right side of the engine (drivers side). I cant guarantee you will be able to get to them though. If not dont worry too much just make sure you back flusht he radiator and flush the whole system including the heater core. I have personally written up a few threads on good techniques of how to properly flush the cooling system so hopefully you found them.
Jack the front of the car off the cross member. Its the very solid looking black piece of steel that runs accross the beneath the engine.
Deren
Hey thanks for all the replies everyone :P
I went to supacheap and the cheapest (only) trolley jack they had was for $180. A bit more than I was expecting...
also, does anyone know what size washer is needed for the air bleed valve near the intake manifold? the manual doesn't mention a size, just that it should be replaced.
Its easy to get to so just re-use the washer and if (most likely wont) it leaks then you can replace it at a later time. Im sure it would only be a couple of bucks from Nissan. Everyone makes Nissan out to be rip off merchants but i can guarantee i have bought more parts from Nissan than anyone else here in my ground up build. I have found that common things can be bought for quite cheap. Sometimes you get a nice surprise and others i'll have to admit you get a nasty shock. However in my mind unless its performance aftermarket gear, nothing beats genuine for quality.
  • 3 weeks later...
hey everyone,
coolant (about 10L)
coolant flush
socket set
ahhh sorry for the long winded thread. thanks for any help ;)
you know u can take your car to a radiator specialist, and he will do all that and more and it will be cheaper than what its going to cost you, my water was rusty aswell a few years back, you have to make sure you put in enough coolant, but also not to much, and you will need to do this every 2-3 weeks, until all the rust is cleaned out,i reccomend u take the radiator out and get the hose in from the bottom, you have to make sure all the shitty rust is out, i did 4 radiator changes in a space of two months, and the last one i took it to a radiator bloke, he changed a few things, high power flush, and new coolant, never had a problem since, he charged me around $85.00
Good on you for giving it a go mate. You'll learn heaps.
You can jack the car up from the cross member (strongest place) directly beneath the motor, or i sometimes jack it from the towing points (big chunky oval bits sticking down on either side of the engine) when i'm in a rush.
Also don't use water to flush anything as it causes the system to rust (bet you've already read that though)
Otherwise you've covered everything. Get stuck into it, take your time, and looking forward to the tutorial ;)
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
