Hey!
I came over a cheap twin HKS 2530 set for a GTR a while ago and now im going to put them into my R33 GTST.
I was planning on going with twins (turbos that is :rant: ) earlier and when these came up i couldnt let them pass me by!
Now i would really appreciate if someone has got some useful information about the procedure, things like going top-mount or not, best way dealing with water/oillines etc. I've looked around alot for twinturbo build pics and found some that are really useful but i feel that its better to know things before i start building then finding it out myself on the way!
List of my mods now:
HKS intake system with the lousy fungys type-filter
5Zigen Catback
Greddy BC
HKS Turbotimer
FMIC
Intank Walbro 255 lph
Inline Walbro 255 lph (disengaged for now)
Cusco Brake cylinder stopper
RPS Max Series Clutch
On their way, as in somewhere in a postoffice :laugh: :
Stand alone engine mangement
Q45 AFM
Injectors (not ordered yet)
I will also rebuild the bottom end in a while but not just yet, but in the meantime i wanted to get the hardware sorted. Didnt mention other mods done to the chassie since they dont matter right now.
When it comes to welding the ex. manifold it wont be a problem since i've done that type of work earlier, its more the basic design im looking for ideas of.
To list up things i would like to get some tips or pics of :P
1. Topmount or not
2. Waterlines
2. Oillines
Any other useful information/tips is really appreciated!
Thanks and cheers!
-David
Give Jeffworld2 a PM.He has just finished putting twin GT-SSs on his 25 :)
He is a friendly chap and im sure wouldnt mind answering some of your questions. But when there is a full moon....thats a different story! :)
awesome look at my twin turbo setup on a 25
http://forums.nicoclub.com/zerothread?id=295315
ok for oil lines u did a 12x1.25 fitting to a -4 an for stainless lines with a 2 male 1 female t fitting for the oil feeds, for return its 3/4 bpst so u need to combine lines and thats block return for oil, now water is 14x1.5 (not tooo sure) u want -6 an lines from feed on block going to the front of the water neck there is a nipple thats what i am using for return any input ?
Power figure??
List of engine mods?
engine mods are tomei valve springs, and oil orifice and metal headgasket, it has rb26 crank and been bored to make it 2.7, running a 740cc inj, power fc, and a custom intake manifold with velocity stacks, running stock r32 twin turbos until i can afford upgrade (wont be for a while) currently it does not run as its missing an assload of parts but it will be running by the end of the month
hah twins are the go lately apparently.
i'm very happy with mine but all the same it could have been done with a single.... but we will leave that one alone for now
we basically split all the feeds at the block, and made an extra oil return and plumbed the water returns trying to keep everything away from the exhausts. im sure you could even bodgey up something with standard rb26 lines if you mount the turbos in a similar position. mine are low mounted and i could probably even get away with r33 gtr dumps/front pipe. in my opinion you may be better off switching to a gtr head and using gtr ecu, makes everything a bit easier and you get the better head and inlet too. i'm running a single afm so the piping is 'interesting' but works very well. a non-afm ecu would make that a bit easier on you.
one day i will take pictures lol. pm me if your after some specific info. it was not simple but is fun to drive. be aware that the exhaust is now 2x as loud lol despite the same catback
i did my oil differantly but water has me stumped, i got feed down just return is a pita, for freed i di da -4 an t from block with 2 -4 lines goin to banjo bolts on turbos
Thanks for all your tips! Really useful ones, especially about the oil and waterlines so thank you both stricnynel0s and jeffworld2
Still waiting for the wheather to warm up alittle so that i can drive it safely to the garage, got it parked at my mothers place for now, not that safe parking it on the street outside my apartment :blink:
As soon as i got it in the garage i can start ripping it apart, and try to get a descent idea for the manifold design, have got some good ideas from your build stricnynel0s. Just talked to a friend who also build twins, but thats in a MKIV Supra aiming at a bit higher figures then me right now, anywas he promised to help me out alot so thats great!
Got a carmeet coming up in a month, can not decide whether to start building it before or after that though, wanna be able to show it, even if that means keeping the hood closed :P
Heres a pic i took 2 days ago, when i drove it to my mothers place, doesnt quite feel like the right enviroment, does it?
http://www.skylinesaustralia.com/forums/up..._829_128353.jpg
Looking at the difference in breathing efficiency through cam specs/timing, and compression ratio, I'd hazard a guess that there would be a reasonable (but not massive) spool advantage towards the 25. Perhaps 250rpm faster to hit max boost?
But then the 26 would make better power, continuing to produce torque as the revs climb.
The disadvantage with running stock 26 turbos would have to be (as usual) the ceramic turbines.
I would have thought the RB26 would be more resposive; larger displacement, better flowing head with larger cams, 6 throttle intake etc. Only down side i can see is the RB26 having a lower compression ratio. However surely a RB25 would still be slightly laggier with twins? Any one that has experienced both cars know?
ive still got vct going, and its fine driving around off boost. lag is a bit of an issue, but i have hks not stock turbos. power starts at around 4 and it screams by 5, but yeah you have to shift already around 7 whereas a gtr still has revs left at this level of modification. i would love a 26 head but its a bit late now
after reading this post
http://www.skylinesaustralia.com/forums/Rb...itting+on+block
i am lost as what to do about water returns, the feed is EZ, but i do not have thestock water linees, i am gunna run an-6 lines from a t fitting from the block as feed, and for return, i was gunna try the nipple on the water neck, should i use rear heater core hose, i also gotta get cooant to my iavc since i change the oil housing to the rb20 one
Big power TT rb25 I had years ago. Photos are recent taken from the current owner, ignor the dust/dirt. New owner ditched AFM and went Djeto Power FC.
Oil and water lines were custom. Low mounted as it was more "stealth". Manifolds were factory cast GTR items that has the flange's cut off and re welded to suit the rb25 stud pattern.
Oversized forged pistons
Fully balanced
O ringed block
Major head work - Huge ports, a/m valves and springs ect ect
275 HKS cams
Custom cam gears
Greddy plenum
Q45 throttle body
100mm+ thick FMIC
GreddyBOV
Power FC
HKS 2530 turbos - Had them rebuilt using larger HKS 2535 wheels
HKS dumps
3inch front pipes
HKS 4inch super dragger exhaust
1000cc Sard injectors
300zx AFM (Might have been Q45, can't remeber)
Apexi pod filter
3/8 fuel lines
Malpassi fuel regulator
please for the love of god.. dont have it running untill you replace those stock r32 turbos.. they will let go on you easily
    • your right the maps for Australia came out in 2017 but are 2010 maps. i got the updated maps SD card put it in and it was the same. Same maps in my Brothers Nissan Patrol. 2020 i think his car is
    • Yeahhhh, the costs have killed me. Spent more than the cost of an engine rebuild and it most mostly servicing and a tune lol.
    • I'm not 100% how the BMW racers do it, but I know from other brands like Merc, moving, and changing the coolers is one of the things. Like getting a transcooler out from infront of the radiator to out near a wheel arch. So some of the stuff you've got crammed in the middle front, spread it out and open up where you can in the bar to get more air in to the sides.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
