please for the love of god.. dont have it running untill you replace those stock r32 turbos.. they will let go on you easily
haha i just wanna break engine with them, i am not gunna try to squeeze milk from a rock !! for the water return lines could i use something like this
http://www.gtfactory.jp/cms/e107_plugins/z...t=22&cat=11
Edited by stricnynel0s
Big power TT rb25 I had years ago. Photos are recent taken from the current owner, ignor the dust/dirt. New owner ditched AFM and went Djeto Power FC.
Oil and water lines were custom. Low mounted as it was more "stealth". Manifolds were factory cast GTR items that has the flange's cut off and re welded to suit the rb25 stud pattern.
Oversized forged pistons
Fully balanced
O ringed block
Major head work - Huge ports, a/m valves and springs ect ect
275 HKS cams
Custom cam gears
Greddy plenum
Q45 throttle body
100mm+ thick FMIC
GreddyBOV
Power FC
HKS 2530 turbos - Had them rebuilt using larger HKS 2535 wheels
HKS dumps
3inch front pipes
HKS 4inch super dragger exhaust
1000cc Sard injectors
300zx AFM (Might have been Q45, can't remeber)
Apexi pod filter
3/8 fuel lines
Malpassi fuel regulator
Wow,
Very nice engine bay - I take it the new owner's had it sitting in his dirty garage for years?
You didn't post up a power figure, or even better a dyno chart?? Would love to know what it made!
Cheers
Wow,
Cheers
Yeh, the current owner works in the mines or something and is never home, he is on the forums, no doubt he’ll come across this thread soon enough and be able to fill you in on all the little changes.
My under standing is, it hasn’t been driven in over 2 years, or close too and has just been sitting in the shed.
I don’t have dyno sheet, or wouldn’t know where to put my hands on one, sold that car way back in 03` or 04`.
There might be one in the zoom mag write up. I think it was number 33.
The hp figures however where 600rwhp on c16 with 1.8bar IIRC and 10.8 @ 128mph at Willowbank
also i had the same idea with the r32 turbos, now have 4 dead ones sitting in the shed.. they just didnt like being removed and put on a different car. i assume they need to be kept full of oil while off which i certainly didnt do. after fitting turbos, rebuilt the motor after bottom end noise, then the built motor was fine but turbos were shite...
so now i have fitted the turbos i initially wanted to after around 2k km's on noisy non-boosting half-blown r33 turbos. soooo much shaft play
but yeah lots of turbos in the shed looks cool? lol
is that the heater core hose ? and which one the top one or the bottom one ? since my car is lhd its all the way on the other side lol ohh well i will do it, its just a barb fitting from the turbo to an6 line at thet cross bracket ?
you might be better off doing same thing in the ottom radiator hose then, that might still be in the right spot? lol
thats worse lol !! i was thinking of returning the water to here http://www.gtfactory.jp/cms/e107_plugins/z...t=22&cat=11 ir maybe even the heatercore
if i use that air water seperator, i could do the two lines to the two intake nipples on it and the return nipple to the water nipple at the water neck on intake side
would it be more cost effective adapting the rb26 head to the rb25 block? how about the intercooler did you have to ditch your old one or did you customise the old one?
for example if i had twin turbos on an rb25 (lets say both can make 500hp combined power) stock displacement and all and if you put that side by side with an rb25 sporting a 2.8L kit and a 500hp turbo (single) which would be more responsive??????????
Assuming compression ratio is the same id put my money on the 2.8 with a single.
I would have thought the RB26 would be more resposive; larger displacement, better flowing head with larger cams, 6 throttle intake etc. Only down side i can see is the RB26 having a lower compression ratio. However surely a RB25 would still be slightly laggier with twins? Any one that has experienced both cars know?
I have a 420ish bhp RB25DETT in a RS13 which I built a few years ago. Very linear power delivery. Used R32 GTR standard turbos. Spools about 250rpm faster than my R32GTR and produces better power.
The only thing I prefer over the RB25 is the RB26's throttle response which is better but the 25 spooled earlier and generally felt more zippy which I attributed to the the NVCS and higher compression.
Change the pistons though, my number 1 piston broke up after two years/30,000 miles of being hammered.
I was thinking that the water return for the turbos could be routed around the front of the engine
to a fitting in the thermostat housing.
Has anyone tried this?
On second thought why wouldn't you just tee them together and use the exhisting return for the factory return.
  • 1 month later...
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
