please for the love of god.. dont have it running untill you replace those stock r32 turbos.. they will let go on you easily
haha i just wanna break engine with them, i am not gunna try to squeeze milk from a rock !! for the water return lines could i use something like this
http://www.gtfactory.jp/cms/e107_plugins/z...t=22&cat=11
Edited by stricnynel0s
Big power TT rb25 I had years ago. Photos are recent taken from the current owner, ignor the dust/dirt. New owner ditched AFM and went Djeto Power FC.
Oil and water lines were custom. Low mounted as it was more "stealth". Manifolds were factory cast GTR items that has the flange's cut off and re welded to suit the rb25 stud pattern.
Oversized forged pistons
Fully balanced
O ringed block
Major head work - Huge ports, a/m valves and springs ect ect
275 HKS cams
Custom cam gears
Greddy plenum
Q45 throttle body
100mm+ thick FMIC
GreddyBOV
Power FC
HKS 2530 turbos - Had them rebuilt using larger HKS 2535 wheels
HKS dumps
3inch front pipes
HKS 4inch super dragger exhaust
1000cc Sard injectors
300zx AFM (Might have been Q45, can't remeber)
Apexi pod filter
3/8 fuel lines
Malpassi fuel regulator
Wow,
Very nice engine bay - I take it the new owner's had it sitting in his dirty garage for years?
You didn't post up a power figure, or even better a dyno chart?? Would love to know what it made!
Cheers
Wow,
Cheers
Yeh, the current owner works in the mines or something and is never home, he is on the forums, no doubt he’ll come across this thread soon enough and be able to fill you in on all the little changes.
My under standing is, it hasn’t been driven in over 2 years, or close too and has just been sitting in the shed.
I don’t have dyno sheet, or wouldn’t know where to put my hands on one, sold that car way back in 03` or 04`.
There might be one in the zoom mag write up. I think it was number 33.
The hp figures however where 600rwhp on c16 with 1.8bar IIRC and 10.8 @ 128mph at Willowbank
also i had the same idea with the r32 turbos, now have 4 dead ones sitting in the shed.. they just didnt like being removed and put on a different car. i assume they need to be kept full of oil while off which i certainly didnt do. after fitting turbos, rebuilt the motor after bottom end noise, then the built motor was fine but turbos were shite...
so now i have fitted the turbos i initially wanted to after around 2k km's on noisy non-boosting half-blown r33 turbos. soooo much shaft play
but yeah lots of turbos in the shed looks cool? lol
is that the heater core hose ? and which one the top one or the bottom one ? since my car is lhd its all the way on the other side lol ohh well i will do it, its just a barb fitting from the turbo to an6 line at thet cross bracket ?
you might be better off doing same thing in the ottom radiator hose then, that might still be in the right spot? lol
thats worse lol !! i was thinking of returning the water to here http://www.gtfactory.jp/cms/e107_plugins/z...t=22&cat=11 ir maybe even the heatercore
if i use that air water seperator, i could do the two lines to the two intake nipples on it and the return nipple to the water nipple at the water neck on intake side
would it be more cost effective adapting the rb26 head to the rb25 block? how about the intercooler did you have to ditch your old one or did you customise the old one?
for example if i had twin turbos on an rb25 (lets say both can make 500hp combined power) stock displacement and all and if you put that side by side with an rb25 sporting a 2.8L kit and a 500hp turbo (single) which would be more responsive??????????
Assuming compression ratio is the same id put my money on the 2.8 with a single.
I would have thought the RB26 would be more resposive; larger displacement, better flowing head with larger cams, 6 throttle intake etc. Only down side i can see is the RB26 having a lower compression ratio. However surely a RB25 would still be slightly laggier with twins? Any one that has experienced both cars know?
I have a 420ish bhp RB25DETT in a RS13 which I built a few years ago. Very linear power delivery. Used R32 GTR standard turbos. Spools about 250rpm faster than my R32GTR and produces better power.
The only thing I prefer over the RB25 is the RB26's throttle response which is better but the 25 spooled earlier and generally felt more zippy which I attributed to the the NVCS and higher compression.
Change the pistons though, my number 1 piston broke up after two years/30,000 miles of being hammered.
I was thinking that the water return for the turbos could be routed around the front of the engine
to a fitting in the thermostat housing.
Has anyone tried this?
On second thought why wouldn't you just tee them together and use the exhisting return for the factory return.
  • 1 month later...
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
