Need to garner some input from the experienced owners and tuners over here. Been running my R33 GT-R for nearly six years, and have done quite a bit to it. To the point where further non-cosmetic mods are a topic I'd like some input for. The car is a pure UK fast road beast, no drag or track. It's a conceptual design by me with all specification, build and tuning by Abbey Motorsport.
Currently on the to do list are a Nismo plenum, Defi centre console cluster holding oil temp, oil pressure and water temp gauges, and a decent TPMS. Plus the full bodywork refurbishment when I crank up enough funds for the work.
To save duplication, here's the current full spec (apologies for daft length; project has got a bit out of hand :) ):
Nissan Skyline BCNR33 GT-R (Type 2) manufactured in April 1996. A JDM non V-Spec retailed through Osaka Nissan Prince in May/June 1996. Vehicle imported to the UK in 1997, remaining in original JDM spec without speedometer conversion until August 2002. Only the steering wheel & white dial sets were fitted in Japan.
Nismo RB26N1 bare engine [N1 water pump, reinforced cylinder head bolt boss, increased sump capacity]
N1 head with 0.5mm overbore (2598cc)
Cryogenically hardened N1 crankshaftWossner forged & cryogenically hardened pistons
Abbey Motorsport reinforced & cryogenically hardened con-rods
ACL Race Series conrod & crankshaft bearings
Tomei sump baffle kit
Tomei high flow oil pump
HKS 1.2mm metal head gasket
Tomei Procam Spec 2 cam kit (270 degree inlet & outlet with 10.25mm lift)
HKS V-Cam System Step 1 Type B (variable 248-278 degree inlet; replaces Procam inlet camshaft)
HKS vernier cam pulleys
HKS kevlar reinforced timing belt
Trust metal intake & throttle gasket
HKS front pipe & decat gaskets
Greddy Iridium 08 Racing sparkplugs
Mocal 19-row oil cooler & Abbey Motorsport remote oil filter assembly
Abbey Motorsport catch tank (& washer reservoir) with SFS breather hoses
Abbey Motorsport Pro Alloy large radiator
Tomei fuel pump, fuel regulator & 600cc injectors
A'PEXi Power Intake induction kit
A'PEXi GT Spec intercooler (237x610x136mm) & hard pipe kit
HKS GT-SS turbos
HKS twin AFM delete kit
Tomei turbo elbows
HKS downpipes
HKS Silent Hi-Power exhaust
Abbey Motorsport 80mm decat pipe
Mine’s VX-ROM
HKS F-Con V Pro
HKS EVC 6 boost controller (1.5 bar)
AEM wideband lambda sensor
Splitfire DI Super Direct Ignition System
HKS Circle Earth kit
HKS GD Max twin-plate clutch (with lightened flywheel)
Abbey Motorsport one-piece steel rear propshaft
Abbey Motorsport rebuilt transfer box
Abbey Motorsport rebuilt gearbox with cryogenically hardened gear set, modified Nissan synchromesh upgrade and OS Giken strengthening plate
Abbey Motorsport rebuilt rear diff
Nismo gearbox mounts
Nismo Solid Shift gear stick (10% short shift)
Omex Shift Light Sequential
Techtom MDM-100N diagnostic display unit
Sunsei SE-135 solar panel trickle charger mounted on a custom aluminium riser between the rear parcel shelf speaker enclosures
Rays Engineering Volk Racing GT-N 18x10 alloy wheels refurbished in silver
Falken FK452 265/35/18 Y-rated tyres
Cusco brake master cylinder brace
Cusco rear steering delete kit
Cusco front & rear upper suspension links
AST Sport Line 1 full suspension kit with UK spring setup
Nismo stainless steel braided brake hoses
StopTech 355mm rotor 4 pot caliper front brake kit
StopTech 355mm rotor 2 pot caliper rear brake kit with Abbey Motorsport modified pad retainers
Ferodo DS2500 brake pads front & rear
Bomex AD-390 front splitter
Nismo R34 smoked front indicators in custom aluminium mounting plates finished in crackle black
Nissan Xenon headlamp units
Front grille refinished in crackle black
Border Racing Aero Fenders (vented front wings) with silver Nissan R32 GT emblems
Nismo smoked side repeaters
Top Mix one-off FRP twin blade rear spoiler on custom aluminium mounting plates
Rays Engineering Volk Racing centre caps for GT-N alloy wheels with custom cast bronze pentagram inserts
Nismo carbon fibre B-pillar plates
PIAA carbon effect silicon wipers, front pair with spoilers, rear without
Nismo white face dial sets in carbon fibre panels
Nissan Momo steering wheel (with airbag)
Dressycar Nismo harness pads
Redline Automotive leather gearstick & handbrake gaiters
Abbey Motorsport carbon fibre door sill trims
Carbon fibre boot sill trim
Custom gearknob hand turned from 200 year old Sussex oak, with hand beaten custom bronze pentagram inset on top.
Inlet plenum and sundry induction pipework finished in powder grey
Trust clear cam pulley cover
HKS Kansai Service carbon fibre spark plug cover
Right hand cam cover finished in crackle black
Nismo radiator & washer reservoir caps
Fusion Fabrication stainless steel fusebox cover with custom etching from Boris Vallejo sketch
HKS Kansai Service front strut brace finished in high gloss black
GReddy aluminium slam panel finished in crackle black
Tein bonnet dampers with black sleeves
Custom made one-off Cobra Misano Lux front seats [Alcantara (colour code 9189) outers, Alcantara (colour code 9182) centre panels, One-piece carbon fibre backs, Sidewinder bases on custom subframes adapted by Abbey Motorsport ,Cobra logo in silver thread on the headpads, GTR logo beneath the grommets on seat backs]
EVC display mounted in custom carbon fibre plate replacing the ashtray.
AEM AFR gauge replaces cigarette lighter socket.
Cigarette lighter socket relocated to fog light switch panel under steering wheel.
JVC KD-AVX2 multi-media DVD/CD receiver with built-in 3.5” widescreen monitor
2x JL Audio Evolution VR600-CXi 6” speakers (front)
2x JL Audio Evolution TR650-CXi 6.5” speakers (rear)
413.2 bhp at 6600rpm
424.3 ft/lb at 3850rpm
Abbey Motorsport hub dynamometer, March 2008.
Edited by Corpsewalker
https://www.sau.com.au/forums/topic/212339-what-to-do-next/
Hello Kitty air freshener?
Love to see pics of your car man :D
When I finally get time off work i'm planning on replacing all the hoses and connectors in my engine bay, restoring or replacing the dash/interior trims and getting a full detail, + anything else to rejuvenate the condition of my r34.
https://www.sau.com.au/forums/topic/212339-what-to-do-next/#findComment-3754082
Photos: Hoping to get some decent ones in a few weeks. Car has either been off the road or the weather has been crap. My photographic skills are shite, so it's getting the time of a couple of friends who are camera capable and some decent weather. Plus a couple of bodywork blemishes dealt with.
Supercharger.... trust me, twin charging has been considered... very briefly. NOS? No. UK road law is funny about it (you can have it but you can't use it? WTF?) Plus it doesn't appeal to me.
Hello kitty air freshner? Hmmm, nice touch. Classier than those plane ol' pine trees or the blue plastic dolphins. But the pink just wouldn't work. :yes:
https://www.sau.com.au/forums/topic/212339-what-to-do-next/#findComment-3763409
Nope, I have a one-piece steel prop instead. Still lighter than standard, still removes the coupling, but costs a quarter of the price.
From what I understand the slight down side of a solid steel (or better chrome molly) single peice shaft is the transfer of harmonics and greater shock loading.
The carbon units in addition to being lighter as a little kinder to driveline components.
They are alot cheaper though.
https://www.sau.com.au/forums/topic/212339-what-to-do-next/#findComment-3768547
Yeah, torque shock is a potential new fun area, but the rear diff was refreshed and toughened a few months ago.
Surge tank/plenum has been discounted as it would deliver no real improvement. It would be very pretty, but apart from that, a bragging rights modification only.
How much have I spent? Enough that I really should know better. Excluding maintenance, it's just under AUS$134,000 over the last six years (you did ask). But when I'm driving, the cost just does not matter. I could never get a car that matches my driving style, environment and reactions better.
https://www.sau.com.au/forums/topic/212339-what-to-do-next/#findComment-3768587
To save a bit of time, here's the main rejects list:
Nismo rear diff has been tried and removed.
Crank damper is not an issue as I rarely exceed the 7200rpm harmonic threshold.
An uprated inlet plenum would not derive any real gains.
A pre-oiler serves no purpose for my style of driving.
High-beam harness rendered irrelevant by xenons.
Lower anti-roll bars irrelevant as I will not be doing trackwork.
Bigger turbos would have to be custom made, so the expense does not justify (yet). Likewise a sequential gearbox, or a significant upgrade in engine management.
https://www.sau.com.au/forums/topic/212339-what-to-do-next/#findComment-3768630
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
