Hybrid Intercooler kit for R32, R33, R34 $1100 UPDATED!!!
$1100. doesnt include delivery. I dont have instruction for S15.
but I can try to get one for u.
I am doing this from a workshop in Sydney. at this stage im not sure if I should mention the name or not because the price is so cheap and I am sure most workshop would be very upset to know that they are wholesaling the FMIC kits out at such cheap price.
  • Replies 101
Jet
Are you saying the fan doesn't need to be cut if tie up the crosspipe with string or perhaps adjust the bracket shape connecting to those two holes?
Also red anodized aluminium with red silicon? Is that a go?
I think u will have to cut the edge of the fan. u dont need to cut as much if u can get something to support the pipe.
I donno how the red pipe with red silicon gonna look like. its all personal preference.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
