Short list of mods:
RB25det spec 2
GT3582R .82ar
Jun style intake
90mm throttle body
550cc Delphi top feed low impedance injectors
JGY fuel rail
Aeromotive FPR
Walbro 255hp fuel pump
Tial 44mm v band waste gate
Hallman boost controller
3" ss turbo back exhaust
Top mount exhaust manifold
Apexi Safc 2
Apexi ITC
93 pump gas
Spec stage 3 clutch
Synchronic BOV
FMIC
Z32 MAF blow threw
This is a 2698lb with driver in it 240sx.
We had some problems with the boost creep so we could only set it at 11 psi but as you can see it creped up to 13.5 or so at about 6100 rpms. Also had some problems with my coil packs.
This is wheel horse power not in shoot out mode.
Correction factors were
77deg. F
60% humidity
60" of mercury
Intake temp was 90deg F
Car pulls like mad all the way to red line. I am very happy with the car as is but I'll more then likely pull the exhaust manifold off and fix the creep problem.
Edited by JonTurpening
https://www.sau.com.au/forums/topic/212349-had-my-car-tuned/
Was not sure of the amount of boost I can run on a stock rb, so we kept it safe at 13.5. What would you recommend? What can these motors handle??
I am going to be pulling out the motor this fall and building it top to bottom. To take advantage of the set up. SO If I can run a higher boost now let me know!!!
Seems like a bit of a waste until you turn the boost up.
Will the stock motor hold up at that amout of boost?
about 20psi depends if you start to get valve float those turbos can run up to 30ish psi. Not sure how well a SAFCII will go just keep an eye on A/F dont get leaner then 12ish to `1 when you are leaning on it.
I had asked my tuner if I needed to get a power fc and he told me with the itc and the safc2 I would not see much of a difference at the level I was running the car. I'll check with him again when I get the coil packs and see what he thinks about running 17-20psi.
I just can't see spending over $1300 U.S for a used Power fc. Then having to spend another $300 to get the tuning software! If need be I'll just get a haltech.
Thanks so much! I am way more familer with US market engines. I.E the VQ35, 4g63, 2jz and the like. I'll have to put the money out on a good set of coils first then it'll be a haltech!
Thanks again guys!
I'm happy with the power it's making now as the car is light. Can't wait to get a Haltech, coils and fix the boost creep!
then get a haltech any standalone will be much better. Yes stock will hold you may need to put a metal head gasket on though. Like I said at that boost some people have valve float issues.
whoops its a gt35/40 (for some reason thought it was a gt30/40) so i would only run the car up to about 300rwkw unless you want to put some forgies in then you can crank the boost push the car well into the 300rwkw range
so thats about 402whp. Sounds good!
I've noticed on the dyno thread for the rb25 that alot of guys post up the shoot out mode on the dyno graph. Not sure if is the same as what my tuner is calling shoot out mode or not. Could someone clear up what Shoot out mode on the Dynodynamics there means??
My tuner is telling me it's crank hp. Is this what you guys are calling it??
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
