Short list of mods:
RB25det spec 2
GT3582R .82ar
Jun style intake
90mm throttle body
550cc Delphi top feed low impedance injectors
JGY fuel rail
Aeromotive FPR
Walbro 255hp fuel pump
Tial 44mm v band waste gate
Hallman boost controller
3" ss turbo back exhaust
Top mount exhaust manifold
Apexi Safc 2
Apexi ITC
93 pump gas
Spec stage 3 clutch
Synchronic BOV
FMIC
Z32 MAF blow threw
This is a 2698lb with driver in it 240sx.
We had some problems with the boost creep so we could only set it at 11 psi but as you can see it creped up to 13.5 or so at about 6100 rpms. Also had some problems with my coil packs.
This is wheel horse power not in shoot out mode.
Correction factors were
77deg. F
60% humidity
60" of mercury
Intake temp was 90deg F
Car pulls like mad all the way to red line. I am very happy with the car as is but I'll more then likely pull the exhaust manifold off and fix the creep problem.
Edited by JonTurpening
https://www.sau.com.au/forums/topic/212349-had-my-car-tuned/
Was not sure of the amount of boost I can run on a stock rb, so we kept it safe at 13.5. What would you recommend? What can these motors handle??
I am going to be pulling out the motor this fall and building it top to bottom. To take advantage of the set up. SO If I can run a higher boost now let me know!!!
Seems like a bit of a waste until you turn the boost up.
Will the stock motor hold up at that amout of boost?
about 20psi depends if you start to get valve float those turbos can run up to 30ish psi. Not sure how well a SAFCII will go just keep an eye on A/F dont get leaner then 12ish to `1 when you are leaning on it.
I had asked my tuner if I needed to get a power fc and he told me with the itc and the safc2 I would not see much of a difference at the level I was running the car. I'll check with him again when I get the coil packs and see what he thinks about running 17-20psi.
I just can't see spending over $1300 U.S for a used Power fc. Then having to spend another $300 to get the tuning software! If need be I'll just get a haltech.
Thanks so much! I am way more familer with US market engines. I.E the VQ35, 4g63, 2jz and the like. I'll have to put the money out on a good set of coils first then it'll be a haltech!
Thanks again guys!
I'm happy with the power it's making now as the car is light. Can't wait to get a Haltech, coils and fix the boost creep!
then get a haltech any standalone will be much better. Yes stock will hold you may need to put a metal head gasket on though. Like I said at that boost some people have valve float issues.
whoops its a gt35/40 (for some reason thought it was a gt30/40) so i would only run the car up to about 300rwkw unless you want to put some forgies in then you can crank the boost push the car well into the 300rwkw range
so thats about 402whp. Sounds good!
I've noticed on the dyno thread for the rb25 that alot of guys post up the shoot out mode on the dyno graph. Not sure if is the same as what my tuner is calling shoot out mode or not. Could someone clear up what Shoot out mode on the Dynodynamics there means??
My tuner is telling me it's crank hp. Is this what you guys are calling it??
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
