  • Replies 66
usually 9.30 to about 4
might aswell sleep in and roll up at your leisure
Yeah that would be good but I cant drive my car after 12 noon on saturday as I got defected..
how long does it take to get to shep?
Of course it does... i used the template from Jesus!!! :) (and they are old tracks, as i had to use old easy ones for the WRX MS round)
Remember that i'm Clerk of course, so all yellow cars will have a advantage. :)
6:15??? ahhhhh that is quite early
i'll probably stick with a lil before 7
around 2 hours
wow so this is what you do at a Motorkhana...haha...the courses look like fun, whats the easiest way to remember the course?
get a passenger to do co-driver rally styles?
yeah that helps..also watching other cars, jumping in as passenger for people..
good fun
It was a good day. Thanks to WRX guys for putting it on.
Bugger about Mat's clutch. Hope you got it home ok.
Can't wait for the SAU DECA coming up!
Aaron. Did you get much good footage/photo's?
yep was a good warmup for sau in a few weeks.
car was perfect all day then when i was one street away from my house it starts hesitating... hope it's just the afm
Bugger. Hope it's not a big deal!
Yeah i continued on with my weekends plans, got it back to the hotel, then drove it winton today, then to greensborough, all with a non-disengaging clutch. Drove by rev-matching between gears then slotting them in...
I was lucky to get from the hotel from winton without having to stop a all, and same again home. Although i had to stop in the middle of the shep town and get my mates to push me along to get started in gear one with huge amounts of traffic....
f**k my f**king flamin mongrel of a clutch it f**ked my whole day at deca the f**king thing and made most of my weekend a f**king waste.
At least my first time was a good time. Where do we see results?
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
    • It really depends on your setup. Mine is 'accidently' more suited to revving higher. bigger cams, turbo etc. Plus my super long first takes donkey years to come onto boost, so if it will move my power band to the right, maybe i'll pass on this. i have a G45-1500 going on there soon which I suspect might make it more of a fat pig.
    • Yeah good call, I will endeavour to tuck that down when I rewrap the looms it’s pushed up by
