Hey all,
I've got a R32 GTR and just had my HKS Twin Plate clutch rebuilt and installed.
Picked up the car last night... go to take off and the clutch's pick up point is right on the floor... like I move my foot a millimetre and can feel the gears engaging.
OK, that's shit... but I can get used to that.
The gears were much tighter but the whole transmission seemed pretty smooth right at first.
As I'm driving it home (driving it easy and not loading up the clutch at all due to the bedding in period), it seems as though as the car is getting hotter the synchro or hydraulics or something is having issues.
First it started not going into 1st gear, so I'd have to put it in 2nd and then shift straight to first... I thought, weird, as the box has never done that before.
Then it started to feel like I was running out of pedal and would have the clutch all the way in but I could tell it wasn't fully disengaging the gears and the revs would drop down due to there still being some contact.
Then on up-shifts into 4th, I could feel the gears hitting and not meshing properly.
Then this started happening in almost every up-shift and was a rough hit of the gears on the way in due to the lack of meshing and sometime would just mash and not go in.
Then the pedal got even lower and I couldn't get it out of gear without slamming it out and there was no way of getting it back into gear (tried all 6 and it was just mash mash mashing - praying I didn't do damage to the box as I was getting a little frantic at this point).
Turned it off, let it cool down, and then I could get it into gear again. Not very easily though.
But, drove it to work this morning and I had to double clutch on every down-shift to get it into gear without mashing, and by the time I got to work, even with double clutching, I could barely get it into first!
Please help...?!
I'm destroying my gearbox at this rate (going straight back to the shop tomorrow morning), but I really hope not too much damage has happened so far...?!
https://www.sau.com.au/forums/topic/212397-help-me/
hi mate, i had the same problem with an older car i had, the friction point slowly moves closer and closer to the floor.
turned out to be my slave cylinder had a hole in the seal and wasnt holding enough pressure for the clutch to disengage.
had to rebuild the slave cylinder only cost about 30$ for the kit, and took about an hr from bonnet up to bonnet down
however it could also be the master cylinder,
or even the mechanic just didnt bleed in the clutch proply when he put it in.
https://www.sau.com.au/forums/topic/212397-help-me/#findComment-3752829
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
    • Twas your car many moons ago that gave me the idea!
