Item: TD06-19C Turbo kit
Age: Unknown
Condition: Good
Price: $1000 firm
To Fit: Any car with a RB20/25
Contact: By pm or on 0401228633
Comments: Bought this turbo to put on my car but have decided to sell the car instead so i will be selling this as i wont have a need for it. The turbo is in good condition but has been used. Comes with basicly everything you need to fit onto your skyline, included is the dump pipe, braided oil line and some pipeing including modified bov return. Has 2 actuators one rated at 10psi and the other 20psi and all bits and pieces ie. clamps, hoses, bolts ect. Pics are below, This turbo is good for around 300rwkw. Welcome to inspect. make me a offer!
Thanks
Brad
Edited by shnaped_second
https://www.sau.com.au/forums/topic/212402-td06-19c-turbo-kit-to-suit-rb2520/
**stupid question alert**
so this would bolt straight up to just a normal RB20DET cast low mounted manifold?
just triple checking....
and how laggy on a 20det...
drop me a PM with best possible price.....
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
