is there a Turbo Attessa R34?? I thought the R32 was the only Skyline with AWD and Turbo?? Thought 33 and 34 only have RB25DE's,
u 100% sure about that Warpspeed?, cos i would be VERY interested to track down a R34 AWD Turbo.
cheers.
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-451056
ok here it goes...
R33 GTS-4 are all non-tubo from factory
there are some R33 GTS-4 that are turbo but only after market using Steagea RB25DET
GTS-4 drive train is not as strong as GTR
there are;
R32 GTS-4 witn RB20DET 4WD
R33 GTS-4 witn RB25DE 4WD coupe/4 Door
R34 GTS-X witn Neo RB25DE coupe/ 4 Door 2WD/4WD
Steagea RB25DEt 4WD Wagon
me old R33GTS-4
cheers
Joe
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-451069
waiting for u to pop ur head up in this thread Joe :)
oh EJ6, Pva_Glue (Joe) had (still has??) a R33 GTS-4. I agree with Joe, i think for a GTS-4 to be Turbo, it has happened AFTER coming out of the factory.
cheers.
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-451071
So that pic is an R33 GTS-4? I'm not understanding that..
There is such a beast?
I've been asking the guy I'm buying it from exactly what it is, and he is telling me that there was an R33 GTS-T with AWD in japan.
I really hope my engine is from the stagea though, that would be cool.
EDIT: and this last picture you just posted pva_glue, what is that?
Basically an AWD RB25DET with attessa? :confused:
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-451148
I found this page on a good search. http://www.jbskyline.net/R33/Sedans/
Now what is the GTS25t?
Anyways, heres a quote from that site.
just like the R32, the R33 sedans came in rear- and all-wheel-drive forms, with 4-speed automatic and 5-speed manual trans-missions available.
:confused: Confused even more now.
I guess the only real way to figure shit out is to live in Japan.....
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-451166
Hi Joe, you finally sold it ! I am still looking for a manual R33 GTS-4, but they are very scarce indeed.
Not sure about your comment on the GTS-4 drivetrain being not as strong as the GTR drivetrain. There are only two differences the clutch, and the n/a cars have only four stud wheel hubs.
If there are any other differences please elaborate, because I have researched this quite thoroughly, and it is exactly why I want a manual car myself.
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-451296
Yea that's what I would have figured. Which isn't a real big deal because I can have put my own in there and lower the compression..
Anyways, I asked the guy what the engine code is (near the alternator) and he told me it says RB25DET..
Do they say that exactly down there?
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-452322
>Nameless EJ6: I can understand your confusion man, that turbo RB25 probably WAS taken out of a GTS-4...
Check the second car down on this site...
It was a GTS-4, but now the owner proudly hails that it's a "GTS-4t", or a mini GT-R. He had a turbo and manifold from a RB25DET bolted on to his RB25DE.
So, there were no GTS-4t's officially, the owners modified their GTS-4's to turbo spec.
https://www.sau.com.au/forums/topic/21242-r33-gts-4/page/2/#findComment-452370
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
