if you're looking for something 'decent to well paid'.. you might want to make more specific mention of what kind of work you've done in the past... You're not going to get a well paid, entry level job... unless you go off to work in the mines maybe..
We need a crane operator/driver and possibly more truck drivers, but not located in Eastern suburbs.
https://www.sau.com.au/forums/topic/212437-need-work/#findComment-3754032
hey i just got a job at australia post driving a van around and emptying post boxes. its 18.56 an hour but after 6:30pm u get 15% loading and if ur whole shift is after 6:30pm u get 30%loading. its only perm part time 5 hour days start inbetween 2:30pm-4:30pm mon- fri and they are either 4 or 5 hr shifts. just and option as wen i went for my interview they had positions in hallam. mt waverley, moorabbin (how eva u spell it)
https://www.sau.com.au/forums/topic/212437-need-work/#findComment-3754070
yea i was thinking if someone legitimately knows of a job i could forward my resume in an email... but yea just a lot of factory work and mechanical, red card, scaffolding ticket, traffic control ticket, general construction cert 2, carpentry pre-app, retail cert 2, fork lift and soon to get crane operators license... maybe.
https://www.sau.com.au/forums/topic/212437-need-work/#findComment-3754867
for those 8 hours, it would be a max of 1hr setting up and packing up, and 30mins standing.....unless you had to use the stop/slow baton
yeah i heard those guys who hold the stop/slow baton get paid heaps - something like 60k or something ridiculous
https://www.sau.com.au/forums/topic/212437-need-work/#findComment-3756214
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
