just a quick question in regards to plates here in VIC. can u put spaces inbetween letters on plates?
a quick example is if you wanted the plates "hotcar" could u have it presented like "hot car"
heres the link for anyone who wants to have a play.
https://ordering.vplates.com.au/plateorders.asp
https://www.sau.com.au/forums/topic/212440-spaces-in-plates/
  • Replies 47
Posted Images
i was actually thinkin about cuttn the plate in half...and welding some metal just to widen the gap.....but im a lil worried it will look dodgy...lol
does anyone know who makes the plates for Vicroads?
its illegal to modify a plate in any way.
i could proberly say the same thing about half ur car.
i know its illegal but we all know thats totally diff from gettn caught lol.
honestly ill give it a go, if i do a good enough job the cops shouldn't even notice
im sure welding a number plate together would look tops :D
not sure welding would be the right choice atm but seriously....just need to cut the plate in half....and seperate it by 2mm...isnt that harddd.....
how could they possibly not notice :D ??
as long as i do a good job should be alright
whats rong with R34 NRG anyway?
nothing i guess....just found better ones.
well obvisioly u should really keep them cause theres no way ur gona be allowerd to modify ur plates
some cops have even had a go about bending my plates to fit on my rear bar
let alone cutting and welding them back together
if ur gona be doing this to ur plates, what else are you gona do thats dodgy as all fcuk?
why would the cops bend your plates to fit onto your rear bar? where did u have em in the 1st place?
no offence buddy but if i listened to every dikhead on these forums i wouldnt be where i am atm.
wats the big deal its only like $400 for plates......if i f*k it up ill just go back to my plates atm
the cops didnt bend them i had to, like many of the other skyline drivers out there as the japanese plates are only 4 numbers whereas standard vicroads issue are 6, so obviously they are gona be wider hench ull need to bend them.... But even if that is the case as stated by vicroads it is illegal to modify ur plates in anyway, i mean some cops will let u go with bending them but to cut them they dont like it and will make u get new plates..
its cause u dont listen to ppl n the forums that ur in this situation now, ur telling ppl that u wana cut and weld plates to fit ur car..... So how am i a dickhead for knowing whats legal to do to the plates? yes i bent mine and so have many other skylines owners, but police do realise that japanese plates are smaller and will let u off, i never went around adn cuit and welded my plates so they could have no spaces like the NZ plates, thats just been a complete fcukwit.
you think money is the answer to everything, well its not
first find some fcuken common sense then u can splash around mummies and daddies cash all u please
:D
Guest
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
