what the hell are u on about? who said anything about cutting my plates to fit on the car????
i think your a bit lost buddy.
im not in any situation wat so ever ive already got plates and they fit fine, what i said was i want new plates because i came up with something better then wat i have atm (at least thats wat i think) and because we cant put spaces between letters i was planning to cut the plate and space it out so it look like 2 words.....i dont know why your gettn upset about it though?
honestly i think ur actn like a lil girl a bit......chill out.
  • Replies 47
Posted Images
K simple answer for you. It will look shit, cops will see, they will laugh. And you will be at vicroads putting up new plates.
Nick was just using the bending plates thing as an example of modifying your plates.
yeh understandable....... still wouldnt mind giving it a go.....
what about ordering plates from QLD? and using em down here? is that allowed?
i rememebr u can make custom plates from other companies or something....seen em around....anyone heard of them?
You can make custom plates from other companies but they are probably just for show purposes. All plates that are on vehicles must be from Vic Roads.
how does vicroads know if a 3rd party company made the plates?
lets say i bring my plates i have atm to some company and told them to make me a copy.....im sure they could......how would police know the diff?
you mentioned cutting plates look what u wrote
im not getting upset about wat u do to ur car
thats ur problem wat ever u wana do fine, but do call ppl on here dickheads when they know what they are talking about
Well when you put it that way if they can get the exact same font and everything then thats fine, but if they chuck in a space in between letters then it would be noticeable that it isn't real as cops see 100's or plates a day they will be able to tell ''hey why is there a space here''
i mentioned cuttn plates to make spaces.....not to fit onto my car.....
i know that its illegal to modify plates man....shit i said it before.....
i know its illegal but we all know thats totally diff from gettn caught lol.
see right there....i said it.....
tru tru....but wat about that diamond dot thats always in some plates?
im just thinkin out loud here guys lol....
Edited by R34NRG
yeh but the way u say that its like u wanted them on ur car
cause where else do u plan to put plates?
if u were gona buy plates for ur windows they go to a place that makes the $20 and they will make them how u like
ur saying to buy vicroads plates and modify them, either way im not gona argue
honesty i was just making sure u know that u cant use modified plates on ur car
to me it makes no difference wether you take my advice or not, your the one thats will be doing what ever you do to ur car
and thats not my problem so thats all im gona say
fair enough buddy, understood
moving along now
just a quick question in regards to plates here in VIC. can u put spaces inbetween letters on plates?
a quick example is if you wanted the plates "hotcar" could u have it presented like "hot car"
heres the link for anyone who wants to have a play.
https://ordering.vplates.com.au/plateorders.asp
NO YOU CANNOT PUT SPACES BETWEEN LETTERS..
Mods close thread, question answered...
Guest
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
    • Ah, I thought he'd wired it to one of the spare ECU inputs! Too long ago since I read that post, ha ha. I've been arguing with radiators, harmonic balancers, alternators and rust since reading it.
