  • Replies 47
Posted Images
yeh understandable....... still wouldnt mind giving it a go.....
what about ordering plates from QLD? and using em down here? is that allowed?
i rememebr u can make custom plates from other companies or something....seen em around....anyone heard of them?
If you want QLD custom plates on your car you'll need to get the car re-registered in QLD which will involve getting a QLD roady, and an address where the car will be garaged up there. But remember a "6 letter" QLD plate is $2500+.
i dont see why you all have to be a bunch of jackasses.
its silly question yes...
but fark caaaamon man
History.
funny you mention seven letter vicroads will be introducing them at the end of this year unfotuntely you are not able to prebook plates which is annoyin.. so until then Ill just have to stick with my 6 letter ones I just brought..
f*kEYD.. and yes vicroads allowed me to get them :)
A silly question that now has been answered... many times...
Now whether he cuts them, welds them or makes love to them, its totally up to him...
This thread has run its course... :D
Guest
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
    • lol no cats running str pipes … might put the high flow back on but I suspect it might effect my ignition timing a bit.
    • That looks a bit like yellowing to me. If the rear bar was looking like that from rich idle, I'd ask the question, do you have a catalytic converter fitted, and fully working?
    • Oh yeah gets really bad down here. I’ll have to upgrade the heater and wind screen wipers as well for optimal performance.
