4my son memorial cruise
posting this for a mate
meet: city west
time: sunday 1.00 pm "day cruise"
gold coin donation, go's to good cause
(hollywood hospital's palliative care unit)
Also to proove that not all import drivers are hoon's!
local newspapers should be attending for when cheques are handed to hospital.
all welcome
:P
https://www.sau.com.au/forums/topic/212455-4-my-son-cruise-30th-march/
sorry if i just crawled from under a rock here. But what is the story about "4 my son" any back ground info, why is it a memorial? I know it is a 180sx that is around perth ( i think swear i have seen it) some kinda explaination would be good.
cheers
i dont know the full story myself hey..
jst put it up for a mate
yeah theres 4my son which is adrian lee's old car..he passed away
to cancer (not sure what type sorry if i offend) last year...hence the cruise
but his little bro has 4my son2 on his 180 aswell
thats all a know lol sorry :D
I Wish i can come with you guys my car has droped a cylinder or coil packs i do not know yet it sounds like a sick Wrx. Any ways i will come down and toss a few goldies in a can for you i shell be in my mates white Peugeot 206
Change your Spark Plugs.. all of them..
Yeh i should b down to there to check it out :-)
-SeS
-SeS
yer okay i will buy a set of 6 today if super cheaps open. thanks just need to find where there are on me 34 lol i am not mechanic minded probly take me 7 hours
i will be there with my skyline sounding shit because me friend will not let me take her car.
Edited by DiNoBoNeS
was nice to see a good turnout of people =)
couldn't stay for long tho had to leave after burswood had work =(
some sweet as lookin cars tho=)
loved the silvia with the CF bonnet with me in the tunnel car sounds awesome!
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
