Not sure what you're trying to ask, but i'll try to answer it
The following is just MY OPINION and may be incorrect or possibly damaging :spam:
This done in what i beieve is my order of performance modification
100% std car - 7psi
Full exhaust system , quality panel filter, bleed valve - 10psi
FMIC - 10psi
aftermarket ECU - 13psi
Upgraded turbo - 18psi
rebuilt engine using quality performance parts - 20psi (pump fuel) / 35psi (race fuel)
All depends on the tunning :D
Boost DOES NOT equal power. Making the engine "breathe" easier and having less flow restrictions produces power. :thanks:
In fact boost produces heat and too much heat results in less power :spam:
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754271
  Ultimategtr said:
Iv heard rumours that if u slap on a TYPE R sticker on the fenders, it gives you 10psi extra boost, just like that, even on non-turbo cars.
thats a vtec sticker you idiot! typeR ones are good for another 1k added to redline
I'm assuming the thread starter is fairly new to all of this so i'll cover the basics, some of which has already been mentioned.
You can just add boost. a bleed valve or ebc will do it. It's virtually useless without freeing up the exhaust first.
In terms of the basic mods, exhaust, intake, intercooler, boost controller, management, injectors & pump, afm, turbo in that order
There is a lot of information floating around, check the sticky dyno thread up the top to give an idea of what mods do what to power.
Edited by BHDave
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754437
thanx for your answer r33cruiser and exspecially Al.
And for you paulr33 go and die. Im not wanting to blow up my engine. And for the rest of you grow up. Why give stuipd answers when there not needed for? I asked a valid question and i got a valid response why add spam to the board and try and make yourselves feel and sound mad? Get a life.
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754850
Maybe if you worded the question a bit better it might make more sense, however looking at the dyno thread at the top of the screen, is a great way to learn what you need to make the power you are after.
PS pauls answer was the exact correct answer to the question you asked
Edited by Adriano
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754895
  John- said:
ow fully sic mate, slap a sticker on the side, grab ya self like 50PSI :) . Everyone knows a sticker dosnt add anything. SO why say stuipd shit? This is what ruiens these forums stuipd responses.
Dude, no.
What ruins forums is people who post the same old question for the 5000th time. And then get offended when it's pointed out.
ffs search you humourless nub.
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3755414
  John- said:
High, Just wondering what sort of mods you can do to a car, any turbo car really weather it be 180sx or a r32gtst. Just wondering what mods let you ahieve a certain amount of more boost? E.G 'blah' adds 1-2 PSI.
  paulr33 said:
just get a boost controller and run whatever boost you like
  John- said:
thanx for your answer r33cruiser and exspecially Al... And for you paulr33 go and die.
Ouch...
:laugh: Paul did technically answere the Q it seemed like u were asking ;)
Edited by GeeTR
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3757121
dude, chill out, paulr33 is right you know, thats what boost controllers are for. you can turnit down to 2psi if you want to. If you run 10-12psi on a normal engine/turbo, its not going to blow up.
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3757147
