Anybody To Swap A Bmw For A Nissan Skyline R33?
By Dewayne2121 · Posted
2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor. Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming! -
I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have. -
Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression. Thanks for that feedback, we'll let you know how this progresses. Fingers crossed. Regards Rob
