Hi guys
I installed a boost controller about a month or so ago, Its one of the new Blitz SBC ID ones. After doing that the car missfires at around 4000 RPM sounds like its farting, but thats not a problem because I am going to buy some Splitfire packs that I think it will get rid of that problem. What I am concerned about is that car surges more that it missfires its like a loss of power for a second and the car jerks (very embarrasing), is this a fuel cut thats happening?
If so what can I do to fix this problem. I do not want to buy an aftermarket ECU.
https://www.sau.com.au/forums/topic/212499-boost-controller-gives-me-a-surge/
I'm having the same issue with my blitz SBC but it's nothing new to me as I had the same problem before. You've probably got a tune on your SBC that's too aggressive. Have you checked your boost graphs at all? I get the dreaded rich & retard (not boost cut, that's a full momentary shutdown) at about 4800rpm due to there being a boost spike to do witht the cam kicking over.
I've wound back the gain & it has suppressed the spike, but it is boosting slightly too high still at that point. A bit more fine tuning & it should be soughted. :banana:
I'm running the SBC i-Color myself. I'm running it in auto mode at the moment & just setting the target boost level & gain. There is a lot of settings on the thing so I've still got a bit of playing around to do.
I'm surprised yours feels flat when you turn the gain up. Mine gave a solid kick in the ass when I had it up at 20 (probably a bit high for a stock turbo but didn't spike) but the boost level was starting to run away when you hit 4000rpm & peaks at roughly 4800 (the graphing function on this thing is gold). I'm running a target boost of about 10psi & I've turned the gain down to 12 but it's still not quite right yet. Raises boost by about half a psi in the same rev range still, which is just enough for the R&R to kick in.
I'll also add I'm still running the side mount intercooler, which seems to be affecting my boost levels depending on the ambient temp quite a bit.
May take me a little while to sought out 100% yet, but I'll post up what I find is reliable as a basic setup.
Edited by J_Red33
Im running 12psi most of the time. But it even does it on 10psi and even when I turn the controller off. The funny thing is after I have been driving for a while it wont do it anymore. The tuner who installed the controller said on all skylines when you increase the boost it runs Rich & Retarted.
Well I've got my tune pretty close to nailed now. Only running a target boost of 10 PSI at the moment, but I found that if I wound the gain down to 9 with the target set at 10PSI, I get very minimal variation in boost & there is absolutely no issues with Rich & Retard.
Having the SBC I-Color I can do RPM based boost mapping so I'm now running a dual map with Gain set to 20 up until about 3750RPM & then down to 9 above that. This set up gives me both a snappy bottom end (full boost as low as 2100rpm!) while maintaining acceleration throughout the rev range. Boost graph is almost dead flat apart from a couple small dips of less than 1psi.
I think it could be even better yet & I may go as far as making 3 or 4 settings for different parts of the rev range. However before I do this I am going to try a similar set up with Manual mode.
Edited by J_Red33
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
