I have just recently bought a 1993 R33 Gts-t manual and was wonder bout a few things. I have already bought a turbo for it (2838) and was planning on going with a R33 GTR intake manifold, R33 GTR intercooler, GTR injectors and throttle body. Would there be any problems with this set up and would i be able to use the standard GTR pipe work from the intercooler to the manifold?
https://www.sau.com.au/forums/topic/212569-r33-gts-t-questions/
GTR injectors are top feed.Standard GTST injectors are side feed.
Will have to modify some things to fit the GTR intake as its not a straight bolt on.
And you will need an aftermarket ECU before you do anything.
You can use all that stuff but it will cost you a packet to do so, firstly you will have to buy all that gear then get an adaptor plate custom made or from Greddy to adapt the RB26 inlet to the RB25 head. Then have to sort all you Vac lines, harnesses and throttle cable the fit the new system. If you get the std gtr intercooler mts and piping you should be able to make the cooler to Throttle body it ok but have to get the turbo to cooler made.
It is very do able but not worth it, buy a RB26 and bolt it in and away you go. Or just get a intercooler and plenum kit from Plazmaman and get an injector upgrade kit from Injectors online, they have kits to change your injectors to top feed. There links are below.
http://www.injectorsonline.com/
http://plazmaman.com/
Good luck,
Ryan
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
