Hi guys, I'm new here, although I have been browsing the forum for a few months now... this is my 2nd post after my intro on the newbie page.
I am buying a R34 GTR in the next week or two. There seems to be many knowledgeable people here, so I would be really grateful if you could help me out with a few questions:
How often do you guys get pulled over by the cops for "routine" inspections even though your car looks stock, sounds stock and your driving is tame?
Why I ask is I really like this moderately mod'ed GTR with stock engine/turbo/intercooler, but has
HKS split dumps
HKS front pipe
HKS hipower catback
HKS adj cam gears (IN/EX)
HKS timing belt with Trust clear cover
Apexi pods
Apexi powerfc adjustable boost
Nismo twin plate clutch (super coppermix)
269rwkw
(Please find a photo of engine bay attached)
Apart from the PowerFC which I can just hide if I get pulled over, and assuming the noise level is ok, do you think this setup has detectable defectables?
Also, the car has had to have a right rear wheel ball bearing replaced. Does this mean it has been driven hard? The owner says no...
The gearshift knob looks quite worn, even though it is a 01' model with 50ks on it. The owner actually imports cars (not his primary job) but this is his private ride.
Any help would be greatly appreciated.
Thanks
https://www.sau.com.au/forums/topic/212587-sh-r34-gtr-a-few-questions-please/
Welcome mate
First question i would ask is why a car with 50'000km would have a really worn out gear knob and a timing belt already changed.
Just be careful. Gets all the necessary checks done before you buy it.
Wow that's the fastest reply I ever got to any post on any forum... thanks krzysiu
Maybe it was driven a lot and then they changed the tacho display set? The kms will be the ones on the new set right?
Or maybe it was just thrashed around.... probably more likely?
The owner is more than happy for any mechanical inspection. I guess you would recommend an RACV comprehensive check?
Thanks.
RACV is useless :)
Take it to one of the many respected w/shops round Melbourne, they will know what to look for and how the car should drive etc.
worn g'knob and changed timing belt do not add up to 50K. It's easy to change the dash or even re-program it, so treat that reading with caution.
Changing a wheel bearing could also mean that the car was in an accident or that he lost control and guttered it.
Get it checked out properly. Trusted w/shops could be found in the "sticky" on the top of the Victoria forum.
If you live in the West/North side my mechanic is listed below.
PS: If you buy the car ask for the stock items, just in case you do get epa'ed. Especially the ecu (which has the true km reading stored).
Ah ok. Cool thanks, I will keep those workshops in mind.
Basically I'm just trying to decide whether to go with light-moderately modded cars or stock GTRs. I really don't need the headache of getting defected, so I would be happy with the stock ones if that's what it came to. Do they even defect things like dump pipes/cam gears? Maybe I should ask this in the EPA sticky?
I have read the excellent "what to look for when buying a secondhand skyline" post but wondering if there is anything specifically about R34 GTRs that have the potential to go wrong and that I have to look for when buying.
Thanks.
Cambelt is often changed as a precaution more than anything. Relatively inexpensive compared to a rebuild if it snaps.
Worn gearstick can be a good indicator but again could have had a nice expensive Nismo item that has been replaced. Seat bolsters, bodywork, panel alignment would help build a picture too. Ben at Racepace knows his stuff in Bayswater and is popular on here. :D
In answer to the question about defecting, it depends on where you drive, how much you drive and how you drive.
Yes it does, you don't have a list of illegal mods there which is a good start. The boost controller and ECU are illegal under EPA rules but its unlikely to get noticed.
The pods may attract a little attention if they check the car but its not illegal unless you changed the FMIC as well.
You guys over east seem to have so many rules in regards in modified cars...
Maybe you guys should consider coming over west! Not nearly as much rules about modifying your car over here!
Thanks guys for all the replies.
Just went to see most of the remaining R34 GTRs for sale in Melb today. There's someone selling one in Leongatha but a 2 hour drive's a fair way away for a test drive, unless I'm on my way to Phil Island... but I only aim to go there for the track after I get my GTR. I'm sick of seeing the penguins already. Has anyone seen the Leongatha one?
I was very impressed by the 3 Nurs I test drove/rode in today. As the car will be my daily driver though, a Nur is pretty much overkill and I should stick with the cheaper GTRs. Yeah I plan to get a mechanical inspection at one of the trusted garages before buying.
With regards to rust, has anyone actually seen an R34 with rust before? I haven't... must be pretty rare, or I'm not looking in the right places :worship:
I just have two more to see in Car dealerships before deciding. Anyone have any experience with GTA Autos on Spencer St or Victorian Auto Market in Fawkner?
Thanks.
Incorrect...its done in the odometre
I am pretty sure the ecu also stores the km reading as well, read it in one of the mag's.
They stated the cluster is easy to change, but you can check the ecu and it will have it's true reading still.
Ok,what you read in the magazine is correct....Ive had the R34 gtr apart to a bare shell,ive had the bonnet's open on most of the computers that are in the car,reprogrammed the anti theft box's on about 5 car's due to lost keys and could tell you what every wire in the car does and what colour it is.....the mags must be right
Edited by ylwgtr2
No need to be abrupt about it.
It would have been nicer if your reply had more tact.
the bottom line is i wouldnt have answered in the thread if the answer wasnt correct...or i would have included a "maybe".A lot of people post information that is not correct or "Ive heard",which is a big headache for someone looking for accurate info in the case of trying to resolve a problem or doing a diagnosis.
Agreed 100% but i wasn't questioning the accuracy of your reply, just the diplomacy of it.
Nothing wrong with being nicer and still making your point, after all, we are a community here with the same interest.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
