If you're changing the cam gears, I'm sure you'd change the timing belt why you're at it...
100% Agree.
Phatboy, if the car is tidy and you're happy with it once you have had it inspected, buy it. Going by the engine bay, it looks rather tidy. If that is a representation on the condition of the car, then I'm sure you have very little to worry about.
If you are happy with the car once you have had an inspection, buy it. Don't let teh Interweb Nazis dictate your decision.
Hahaha couldn't agree more. Steering wheel, gear knob and seat wear and THE biggest tell tale signs of a cars age but, imagine this as crazy as it may sound, a Japanese man, perhaps like someone you know.....enjoys his car and drives it often....pwoah! :D Just imagine!
I'm no expert but I don't believe driving a car "hard" would cause wheel bearing issues. Could be wrong though.
Got any more info on the car? Pics, links etc?
Ok,what you read in the magazine is correct....Ive had the R34 gtr apart to a bare shell,ive had the bonnet's open on most of the computers that are in the car,reprogrammed the anti theft box's on about 5 car's due to lost keys and could tell you what every wire in the car does and what colour it is.....the mags must be right
Yes if you change your cluster the km reading will display what is stored in the cluster, so a new cluster will show 0 km.
I agree with that.
The magazine also stated that a km reading can be extracted from the ecu.
But if you have re-programmed an R34 ecu, and know what every single bit does in it's programming, i'm happy to accept that you know more than everyone else :).
Ok point made.
I will try to get the factory ECU. Only thing is, how do you know when he changed to an aftermarket ECU if the owner bought it like that?
The factory ECU could have been changed 5 years ago, and you wouldn't know how many genuine km's he's done after that.
But I will keep it in mind, thanks.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
