SK, I might be misunderstanding, are you saying that if the revs aren't excessive then the rods should be able to handle a lot more than 4-500hp? I have my 30 limited to 6800rpm, reckon I would be able to push more than 400rwhp on the stock rods with that limit?
The real question is what is excessive RPM? Remember RB30's barely reved over 6,000 rpm standard. Adding around 500 rpm = double the load on the pistons and rods, so at 6,800 rpm you are already way more than double the standard loading.
Cheers
Gary
Hmm, well that's not very comforting :/
Would it be advisable to lower the limiter? I don't rev past 6000rpm now anyway due to the tiny rb25 turbo choking the engine up and I've got taller diff ratios which help with the lesser rpm..
I imagine with the GT35R strapped on there I'm going to have an abundance of torque and might not necessarily need to rev it to 6800..
Hmm, well that's not very comforting :domokun:
Im going to be reving mine to 7200 once its tuned, I reckon 6800 is being a bit too concervative especially with forgies make sure you got a really good tune and it shoud be apples!
I was answering a question about standard rods and pistons, hence the mention of the 6,000 rpm
Cheers
Gary
Cheers
Gary
Fair enough, just want to get this straight in my head are you saying not to rev over 6k with stock pistons and rods?
If only it were that simple. There is more than one limit on the strength of components question, there is knock, boost, RPM and torque to start off with. Keeping in mind that BHP is simply torque x rpm. For example, I hear quite often 400 rwhp is OK on the standard components. Well it isn't if you are using 7,500 rpm. It also isn't OK if you are running 1.5 bar of boost. Not to mention 70 plus knock all the time. My rule of thumb is quite simple, no more than 475 bhp (around 300 rwkw), 1 bar of boost, zero knock and 6,500 rpm limit. A standard internals RB30 will live a long life within those limits, I built one in 1999 that is still going strong.
Cheers
Gary
  • 3 weeks later...
What about machining? some people say they've had theirs machined, though i thought RB30 cranks were nitrided from the factory and therefore, not a good idea to get them machined? can they be re-nitrided?
Yes, although if the crank needs machining, its easier/cheaper to get one that doesn't
had mine machined etc and even nitrided for good measure. Argo rods, ceramic coated cp pistons, jun pump and collar, ati balancer... All balanced. Setting rev limit to 8000rpm...although it will only be bounching at that over the dyno..I think street tune will be 7000rpm.
stock crank nitrided i can vouch has handled 1068 rwhp @9000rpm 10 000rpm in burnout also threw 2 rods and the crank was still true. but im very interested in the stroker kit for the rb30
was there any mods done to the block???
block was std never ran an oversize over 87mm yet,usuals like drilled galleries gtr head studs etc
this year the engine is grout filled running methanol and is solid mounted
Edited by jas/slo32
  • 4 weeks later...
  • 1 month later...
