Crank Strength And Upgrading Options.
Prototype crank is about to go into production, rods and pistons have been designed.
Still all a few months away - but its all happening :-)
Any news spool on the 3.4L Kits?
Edited by Spoolup
The 3.4 should be very interesting, did you stick with 86.5mm bore and what style/shape of rod did you chose?
I presume you've made it so its a drop in kit for a stock block?
Rob
Edited by R.I.P.S NZ
The pistons are 20 thou over so ( 86.5 ), they will also be available in 40 ( at some point ).
The rods are a custom H Beam.
Drop in kit for stock block is the aim :-)
Cool, what is the actual cc rating with the 86.5mm bore?
Rob
pffft. whatervaa......... just anticipating someone thats prepared to spend 6k on a rotating assembly might want oil squirters. not me but im not everyone.
just have a japlish disclaimer, oil of the squirter instalation faliure...
I have never had a RB26 in the 240z, its always been a RB30, stock block, stock crank, RIPS wet sump etc and anyone who says a stock 30 crank won't rev hard or is limited to 7500 etc is talking rubbish
http://nz.youtube.com/watch?v=nHLfRseF_F4
http://nz.youtube.com/watch?v=G6qtA0_kQUc
9500-10,000 rpm during burnout
Rob
everytime i see this 'cocaine' car on the strip i get goose bumps - sounds better than a moaning hottie :blink:
to get a comp ratio here is 1 formula i work with
bore x stroke (bore =86.5mm stroke =95mm)
86.5 x 85.5 / 4 =1870.5625
1870.5625 x 3.142 x 95 = 558344.2006
558344.2006 / 1000 = 558.3442
litres
558.3442 x 6 =3350.0652 (the cubic centremetres of the block)
3350.0652 / 1000 = 3.3500
Deck height
i wont be running one but the formular is the same as the bore x stroke formular just replace the stroke with the deck height measurement
Head Gasket
I HAVE NOT REMEMBERED A MEASURED HEAD GASKET THIS IS A ROUGH GUESS
similar 2 the bore x stroke just replace the stroke with the squashed thickness of head gasket and measure the bore of the gasket, or could always CC it with a burette
i.e
87 x 87 / 4 =1892.25
1892.25 x 3.142 x 0.9=5350.9045
5350.9045 / 1000 =5.3509
Head CC
mines 62cc's atm
Piston dish/dome
if i get the kit id run a 12cc dome
add deck height, head gasket, head cc's, piston dish cc's (minues if dome)
0 + 5.3509 + 62 - 12= 55.3509
add the bore x stroke with the above
55.3509 + 558.3442 = 613.6951
devide answer with the above
613.6951 / 55.3509 = 11.08
11.08:1 is the compression ratio id be running
congratulations rob!
and u have this car for sale!? why sell such a beast
I want to get into something lighter, its about 200kg over weight for the Pro Import class I run in but I don't want to strip it out to be a full race car, as it is, it still has glass windows (except doors), steel hatch etc, just needs headlights and wipers back in and its road legal again for someone else.
Rob
    • Hi everyone, I bought the Redline diff oil and the seller has sent me Redline 75W90NS even though that’s not what’s pictured.  I’ve already booked a hoist to go and change my diff tomorrow but I’m not sure if the NS is ok for the rear diff in a R34 GTT I think the NS does not have any slip modifiers so would that be an issue?    thanks in advance
    • Not easy to find pics from 15 years ago, but here is a partial one. Keep in mind that it curved immediately from the airbox, then kept a straight line for the MAF to read correctly, followed by a 45 degree bend straight down to the turbo. This connection was the most difficult as it had to twist as well as bend to meet the almost vertical straight section of the intake.
    • Yes, well, wrt a wheel alignment, there are two types. Either: You have very little added adjustables, in which case the alignment can be done by anyone in any tyre shop or equivalent, and will only take 30 minutes, and so there is no reason to even consider leaving the car there. OR: The alignment is a major exercise because you have adjustables everywhere and so you will need to be taking it to a shop that is skilled and experienced at setting up race cars and the like, and you won't need to worry about leaving the car there.
    • does anyone know the specs of the R35 master cylinder, rear ratio and knee point? the BM57 is a 0.4 rear ratio with a 435psi knee. I'm looking for someone with a much lower knee pressure. the piston area of the R35 brakes isnt that big so might not work for me but this is interesting.. the other option for me is a GU patrol master cylinder and booster and do the prop valve externally.
    • It sounds like by avoiding maintenance you may be doing more damage than a hypothetical guy in a workshop taking it for a spin. Not sure if you are just being paranoid or things are actually that bad in the US. Find a reputable shop not run by dickheads. Look for people that take pride in their work. Stick around for the day if you have to
