They are as relevant as a 7000rpm limit on the std crank.
100% agree on the point you're making, but I'm trying to make a different one :)
my standard rb30 crank goes to 9000rpm no probs so yeah I really do understand what you're saying :(
Nice to see the 3.4lt project is coming along still.
Im just guessing, but if the compression heights are kept to a lowish 28mm and the custom rod length is about 152mm to suit the RB30 block, the rod ratio works out to 1.6:1.
I've just run a few numbers on my engine calculator and for a street application with a degree of reliability 8000 rpm would be the absolute upper limit (including a missed gear shift). 8500 rpm would be pushing the limit of what the rod bolts and pistons will tolerate and 9000 RPM will break a conventional designed forged pistons as piston speeds exceed 46m/s.
Also at 9000 RPM the acceleration away from TDC/BDC is 54.5 m/s ^2. Numbers like that are only seen in all out drag engines. ie... engines built entirely from top shelf custom parts the likes of carillo/pauter with wmc5 bolts and special piston designs. Titanium rods would go a long way to improving high rpm reliability as the rotating mass and rod big end loads are considerably less due to less inertia during the acceleration/deceleration phases of the engines rotation.
Do you feel like running the numbers for a std stroke rb30 for a comparison?
Well rob @ rips revs his engines past 11500rpm and this is with the factory rb30 crank and making over 1400hp. Need i say anymore?
yeah I think you've missed the point aswel mate
my standard rb30 crank goes to 9000rpm no probs so yeah I really do understand what you're saying :)
For a few dyno runs, with lazy driving for 10k-km's or are we talking a SOLID 30,000km's with the ass wringed out of it for streeter duties/drag days? :(
There is a... sizeable lets say... difference between the two.
BTW - i know the point you are making, not covered in the above i know :P
Sorry but Im not so good at making graphs. Ive got one other table that shows piston speeds and acceleration through 360 degrees crank rotation, and the comparison of the tomei to the HKS kit is really very little when comparing the two engine setups. Really the 119.5 rod was only made as an option to allow the use of a thicker crown piston that uses a conventional RB26 30mm compression height. Its well known that the 2.8 kits are safe for 10k so I didnt bother calculating the 8500rpm values.
Ive attached the rest of the table. You might recall the Racepace 2.9 spaced block engine that used a 84mm crank and SR20 rods as well.
At 9000 RPM the piston acceleration for a RB30 is 47.5m/s^2.
The most important thing to keep in mind is the whole point of having a stroker engine is that you dont have to rev the hell out of the engine to make reliable power. That extra 400+cc of capacity will do for the RB30 what the RB30's displacement does over the RB26, if that makes sense.
The beauty of the larger displacement AND the shorter rod ratio is that while the engine doesnt need to (and shouldnt) rev as much as another type of engine, the faster piston accelerations from BDC and TDC mean better cylinder filling making for a more torquie engine. The cylinder pulls into a vacuum faster on induction cycles than a higher ratio motor will, so the engine breathes more efficently.
I agree with Marko's comment that there is nothing wrong with the strength of an RB30 crank. Rob @ RIPS certainly has proven that time and time again. I do wonder what kind of rods and pistons are in his 11,500RPM engine though, im guessing aluminium/titanium and some very fancy pistons. The inertia loading of chromoly rods and pistons at that engine speed would be increadably high. Acceleration factor of an RB30 crankshaft at 11500 rpm is 77.5m/s^2. That is a 1/2 again as much as the RB30 at 9000 RPM.
Ash I think it's just not coloured correctly?
Yes thats it. I always was better at maths than I was at art, especially past 12am.
New table attached.
Edited by GTRNUR
My point was that this setup was never designed to be a big rever.
It was designed to ( compared to the equivalent setup in an normal stroke RB30 ) to make considerably more torque, bring boost on earlier and make same power with less boost and less revs.
So if it makes the same peak power as my current RB30/25 with less boost and less revs, and more torque and comes on boost earlier - Ill be happy.
If it revs to 7500 rpm then it realisticly should make more peak power than my current setup as that is what Im revving it to now, due to the increase in capacity.
    • Yucky. Things haven't gotten any better though. Now you have Emerson and Honeywell pushing these massive DCS/Scada things with proprietary hardware. They're not a PLC, they're not a computer, they're a...distibuted PLCish/DCSish monster of thing, that only they can program because they make the barriers to entry for anyone else so fricking high. And their developers are all located in the third/developing world (and India, in case anyone does not include that place in that category) and there are terrible failings of the ESl variety, of the care and common sense variety, and f**king forget about Functional Safety. Not a one of them has any idea what it means to comply with an IEC 615xx series standard.
    • All of the ECU grounds are to the chassis, the IGN grounds are to the cylinder head and i believe all the OEM body harness are left in original locations, im trying to work out if i can tell if the sensor voltage itself is losing any power to it from the very low ECU voltage. But yeah a manual pressure gauge will help in picking which path to actually chase. Also please dont bully my wiring plan i never designed it to be universally understood hopefully it still can make sense to you, im a wiring virgin.  1 thing i have just noticed the pressure sensor in question relays both pressure and temperature, the temperature reading holds nice and steady despite the low ecu voltage but the pressure reading is the one that jumps around alot so maybe it is really a pressure issue? wiring plan.xlsx
    • Gday, Due to not finding much up to date info on this topic I thought I'd make a thread to get peoples latest opinions/recommendations. Background info -  I've got a S1.5 R33 GTST as a fun project car, mainly for street use and occasional drag strip, apart from all the cosmetic things I'll be doing a full rebuild of the engine with forged internals. Since it'll be getting new cams (kelford) and springs to match I thought I might as well get new lifters and valves while I'm at it, the dash says 160k KMs but the engine seems pretty tired, compression measures about 130psi across all cylinders so I'd like to freshen everything up. This is where I'm tempted to just fork out the extra and go solid lifters while it's all apart, aiming for 400-450kw atw with a flex tune. Assuming all supporting mods (oiling, fuel and all bolt ons) with a lightly ported head and turbo to match (yet to make a decision possibly gtx3582r or similar from Hypergear) I've seen the Tomei kits with just the buckets getting around, Supertech sells most things - Supertech High Performance Cam Followers | Trusted Racing Cam Followers Questions -  Has anyone found the Hydraulic lifters to limit them at this power level? Is it usually found that you can just clean the stock lifters and find they work fine?  Does going solid lifters save any headaches/issues with hydraulic lifters in the future? Any recommendations on other things that will need to be replaced, I know I'll need to get the solid profile cams but can you use the same type of valves and springs/retainers and is it recommended to change the guides and stem seals?    Summary -  Basically looking for pros/cons and wanna know if I'll actually need the extra RPMs from solid lifters or it'll just be bragging rights to say it ReVs OvEr 8000 Cheers
    • Ha ha ha, this stuff they had was installing Toshiba PLCs that were made some time in the 1990s, and they were replacing GEM80 PLCs. To let those two talk (staged upgrade along a ~1.2km long building that was split into 4 sections), was a bunch of WinXP machines running Java gateways... There was no way to put something like ProfiSafe in... Most of the HMI machines were WinXP, with Java program, with a custom button board emulating a keyboard... About the only buttons in the operator stations that went direct to the PLCs was the eStop. There was some interesting design stuff in that place...
