SK, I might be misunderstanding, are you saying that if the revs aren't excessive then the rods should be able to handle a lot more than 4-500hp? I have my 30 limited to 6800rpm, reckon I would be able to push more than 400rwhp on the stock rods with that limit?
The real question is what is excessive RPM? Remember RB30's barely reved over 6,000 rpm standard. Adding around 500 rpm = double the load on the pistons and rods, so at 6,800 rpm you are already way more than double the standard loading.
Cheers
Gary
Hmm, well that's not very comforting :/
Would it be advisable to lower the limiter? I don't rev past 6000rpm now anyway due to the tiny rb25 turbo choking the engine up and I've got taller diff ratios which help with the lesser rpm..
I imagine with the GT35R strapped on there I'm going to have an abundance of torque and might not necessarily need to rev it to 6800..
Hmm, well that's not very comforting :domokun:
Im going to be reving mine to 7200 once its tuned, I reckon 6800 is being a bit too concervative especially with forgies make sure you got a really good tune and it shoud be apples!
I was answering a question about standard rods and pistons, hence the mention of the 6,000 rpm
Cheers
Gary
Cheers
Gary
Fair enough, just want to get this straight in my head are you saying not to rev over 6k with stock pistons and rods?
If only it were that simple. There is more than one limit on the strength of components question, there is knock, boost, RPM and torque to start off with. Keeping in mind that BHP is simply torque x rpm. For example, I hear quite often 400 rwhp is OK on the standard components. Well it isn't if you are using 7,500 rpm. It also isn't OK if you are running 1.5 bar of boost. Not to mention 70 plus knock all the time. My rule of thumb is quite simple, no more than 475 bhp (around 300 rwkw), 1 bar of boost, zero knock and 6,500 rpm limit. A standard internals RB30 will live a long life within those limits, I built one in 1999 that is still going strong.
Cheers
Gary
  • 3 weeks later...
What about machining? some people say they've had theirs machined, though i thought RB30 cranks were nitrided from the factory and therefore, not a good idea to get them machined? can they be re-nitrided?
Yes, although if the crank needs machining, its easier/cheaper to get one that doesn't
had mine machined etc and even nitrided for good measure. Argo rods, ceramic coated cp pistons, jun pump and collar, ati balancer... All balanced. Setting rev limit to 8000rpm...although it will only be bounching at that over the dyno..I think street tune will be 7000rpm.
stock crank nitrided i can vouch has handled 1068 rwhp @9000rpm 10 000rpm in burnout also threw 2 rods and the crank was still true. but im very interested in the stroker kit for the rb30
was there any mods done to the block???
block was std never ran an oversize over 87mm yet,usuals like drilled galleries gtr head studs etc
this year the engine is grout filled running methanol and is solid mounted
Edited by jas/slo32
  • 4 weeks later...
  • 1 month later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
