what would you charge for the rb30 stroker crank and rods?
you mentioned making forgies with it, but me and i notced a few others have gone the N/A path so just wondering if you were making non forged pistons to suit?
are you going to make these reguarly or made to order or just the 1 off batch?
any reason to why your not making this kit with a non forged piston? (not everyone wants to go the forced induction path)
can the kit be bought without the pistons?
whats the height difference between the normal rb30 piston and the piston for the 3.3?
i've been told there are pistons that have a shorter skirt that will suit the rb30de im building, cant remember the part number but what are the chances of them suiting?
do you balance the cranks?
will the 3.3 crank have knife edging or standard counter weights?
Shaun O - around the $6500 - 7000 mark with the AUS dollar at its current rate. It should see 7500 - 8000 plus rpm depending on setup.
Gerg R31 - The reason is that you are the only person who has mentioned it, so Im presuming demand is minimal especially due to the price involved. The other reason is that no one readily and easily makes cast pistons in short runs or one offs. I could easily make you a forged piston for an NA set up though. You would just have to spec the comp ratio you require. The length of the skirt has nothing to do with the comp ratio.
Edited by Spoolup
i just thought you may have designed pistons that were shorter to suit the stroker kit, if the over all height of the pistons dont change i might still be able to get the ones i had in mind, though i know forgies handle heat better
im aiming at around 10.5:1 to 11:1 comp ratio so if you made me a piston the rb25de piston dome with valve releif would be fine with me
plus i work at a machine shop so decking and other machine work and balancing etc is easily done
are you making the kit pistons dome with valve releif? flat top? or dish?
(i know alot of questions but more info may also bring more interest)
Edited by Gerg_R31
im sure that would be ok due to the lower rev range of the 30.
Well the rb26 in thier Z drag car is seeing 10,000 rpm with the tomei pump so i would think rob has something sorted...
Spool, so you 3.4L kits will rev to 7500-8000rpm?
We will have to wait and see - but similar setups with the 3.4L 2JZ ( near identical bore stroke ratio ) have gone 8000 plus easily enough
I have never had a RB26 in the 240z, its always been a RB30, stock block, stock crank, RIPS wet sump etc and anyone who says a stock 30 crank won't rev hard or is limited to 7500 etc is talking rubbish
http://nz.youtube.com/watch?v=nHLfRseF_F4
http://nz.youtube.com/watch?v=G6qtA0_kQUc
9500-10,000 rpm during burnout
Rob
Edited by R.I.P.S NZ
Rob
Bah you know i mean't. :P
Lol, clam down, its all good :) I was just correcting your 26 comment, nothing else in my post was directed at you.
I'm calm, its you rb30/26 thats the angry one. More nos, bigger injectors, more boost, less tit grabbing at the nats, and do some 7's :P
I'm calm, its you rb30/26 thats the angry one. More nos, bigger injectors, more boost, less tit grabbing at the nats, and do some 7's :happy:
Yes sir!! lol, I'll get all the non car stuff out of the way the night before, lol.
Next meet is this Saturday then another the following Sunday so I'll give it my best shot.
Rob
  • 1 month later...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
