just half moon slot the sides of the conrod on the edge of the bearing seat, side face. Simple :wacko:
what are you on about?
bearing seat? you mean the tangs (little notches in the big end tunnel of the conrod) or you talking about the actual big end tunnel or big end journal?
1/2 moon slot the sides?
i was talking in reference to oil squirters....
not the tang. I said on the side of the conrod. ill put up a picture...pretty well most conrods have this done nowadays...
i understand but i think they ment the oil squirters that sit in the crank case area just under the sleeves
i believe this is about as good as it gets as its pretty painful to setup a proper oil squirter system like those in a 25/26. Admittedly it would be good for reduced piston heat...but your also adding more oil to the windage foundation. And that is an area that not alot of people look at, or even know exists.
  • 3 weeks later...
i did find a 100mm rb stroker crank through one of our customers, he is asking for 7400 for the kit, though with some v6 stroker cranks from them the quality wasnt the best, on dummy assemble we found the strokes varied per cylinder and we had to off set grind a plus 30 to rectify
  • 4 weeks later...
I have 2 RB30 stroker crank samples , 12 custom rods and 12 custom CP pistons due mid July. A trial engine will be assembled and run, then if all is ok production will start.
So hopefully all things being equal Ill have kits ready to go Nov/Dec this year.
I just received my first CA18 and SR20 stroker cranks - pics or of CA18 87.6mm
Edited by Spoolup
Nice work! look like I'll be building a 3.4L on the side come Xmas :P
I put a post on the NICO.com CA18 about the cranks, they were interested a while ago when i mentioned in a thread about aftermarket CA rods that you were making a stroker crank. Keep an eye on it if you want.
Here's the NICO thread i'll post one up on NS.com as well;
http://forums.nicoclub.com/zerothread/4341...ker-crank-876mm
P.S. whats the cost of the CA crank?
EDIT!!
The NS.com thread;
http://www.nissansilvia.com/forums/index.p...howtopic=393047
Edited by D_Stirls
  • 1 month later...
  • 1 month later...
does anyone know if you can buy the colar that you screw onto your crank, or do you make it?
my engine builder is asking me to find out as i think he didnt put one on when he built my 17k RB30/26 build of only 2000k before it broke the brand new N1 oil pump gears the first time i gave it a decent rev.
whats the best option?
Aproxx 600rwhp
Yes you can buy collars (Spool, among others, sell them).
Not exactly screw on though, you have to machine the snub of the crank down, press the collar on then drill/tap for grub screws.
Edited by bubba
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
