There somthing wrong with my R34 (GTT-no engine modification)... It began long time before I was cruising down the freeway, and then some dude went to change the line, so i just released a bit of my gas pedal then when he moved lane i tried to accelerate again but all of a sudden the engine, TCS off, slip lights came on, which apparently results in my car wont accel like it should do, the sound from my exhaust is somehow roaring and coughing.. and it does vibrate more when u tried to boot the gas pedal... But when I pulled over, and leave it for a minute or two, its completely back to normal, but u can smell like rubber burning from near the rear wheel... Keep getting this kind of problem but not too often, anyway my 5000k service is due in 2 weeks anyway, i thought so ill just wait..
Anyway I brought my car to 5000k service over in down under auto who also imported my car.. ask them bout the problem, but after the service they said nothing's wrong with ur car
Well the problem still came occasionally and will be gone if u leave it for a minute or two, went to the auto tune once and they said u gotta go to a garage who has the computer shit for R34, so it is easier to find, just plug it in and u'll know where did it go wrong...
I havent had a chance to do it though since i dont know which garage has one.. and the problem didnt pop up lately...
But around 5 days ago the problem came again when i actually wait for my order in mcd drivethru without anyhing to do with the gas pedal or clutch and another one came yesterday when i waited my friend with an engine on like exactly happened in mcd drivethru?
So has anyone overcome this problem or have any idea about what it is? Help me guys!!?
Thanks alot for reading it anyway...
https://www.sau.com.au/forums/topic/212608-r34-problem/
Could be a whole multitude of things rather than just one problem...
Any Nissan Dealership with a service department should have a CONSULT which just plugs in to the ecu port underneath your coin slot
It will check for any error codes recorded by the factory ecu.
Sounds like it could be one of your coilpacks is dead/dieing which might explain why the problem is intermittent,
I haven't checked for awhile... but I think the TCS,SLIP, and ENGINE lights come on when your call stalls or is close to stalling(I was teaching the g/f to drive manual and I *think* I saw those lights on the dash come one when she stalled, was a while ago), which again could be related to a shagged coilpack
If it turns out to be that I'd recommend buying a set of splitfire coilpacks off one of the traders here in the For Sale section of the forums, Splitfires are just like nissan ones but much cheaper to buy compared to genuine
Good idea to check the condition of your Air Flow Meter,
other than that I'm out of ideas...
Goodluck mate!
Edited by Yo-Yo
https://www.sau.com.au/forums/topic/212608-r34-problem/#findComment-3755893
  • 2 months later...
hey my r34 had the engine , slip and tcs off light come on aswel, consult says primary ignition(( my car was at mechanic for 3 wweeks after he told me my ECU was f**ked, before he came back and said its just ya coils..
if you do a search there is a few others had the identical symptons
all were fixed with replacing coil packs.
(( however my mechanic jsut put a new earth to mine and they have lasst an extra month, but im replacing them next week.
i might be wrong, but like i said, exact thing happened to me
https://www.sau.com.au/forums/topic/212608-r34-problem/#findComment-3959473
Recently my engine light starts popping up...only the engine light though...it pops up and goes away and comes up again. Car drives normal but i am abit concerned. The engine light on can't be a good thing. recently had a service also...Any ideas on what it could posibly be?
Cheers
https://www.sau.com.au/forums/topic/212608-r34-problem/#findComment-3968673
    • Just cut the bottom of the guard out. It's no longer got a big duct, to a sealed box, or a restriction. It has all the cold air from outside. Also, that cai you showed looks terrible. Bends are NOT good for go gos!
    • Like I said, "black magic" LOL In the end,  it is what it is, and hopefully, what this here knuckle head has done is an improvement and not a hindrance Not that I actually notice any negatives now, or that I will get any seat of the pants benefits when all is said and done, but best practice says I shouldn't be pulling intake air from the hot engine bay  Famous last words: I cannot see it being any worse than what it is at the moment 馃
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
