Hey, I'm looking at some 550cc injectors to go with my hi flowed R33 turbo. Will the stock ecu rechipped run these well?? Will 550cc be too big ??
Also I'm getting a walbro fuel pump, will I need a aftermarket regulator as well or will the fuel pump and 550cc injectors be ok.
Current mods are basic stage 1 ie FMIC, Exhaust, EBC.
Cheers, I'm only after about 200rwkws so will standard injectors with the walbro and aftermarket regulator get me there? The R33 turbo is being rebuilt with ball bearings and steel wheels etc so that should be fine for this power.
Yes I have my eye out for some GTR injectors but these 550cc second hand ones I've seen are only slightly more expensive than GTR ones.
440cc GTR injectors will be more than enough, they will also drop straight in
Save the little extra money and get the GTR injectors then spend some extra money and get them cleaned and flowed to make sure they are 100% working and won't leak or die once installed on the car
I also suggest new o rings
You will also need to factor in a resistor pack as the standard RB20 injectors are top feed high impedance and the GTR and most others are top feed low impedance
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
