hello hello ppl
well iam looking for sum info on a garrett to4e turbo of mine cause it does not say enything sep
garrett - a\r.50 so ill post up sum pic i got of it and can u let me no if it is a t042 or not
thanks
duncan
https://www.sau.com.au/forums/topic/212634-garrett-to4e/
Particularly if it's a new unit, I would be looking for some sort of build plate on the centre cartridge to identify its specifications.
I don't know that I'd have any issues with some casting imperfection on that comp cover though. It's either structurally flawed, or just a cosmetic thing. Pull the cover off and have a look inside. That will tell you whether to be worried about it or not.
I do think there needs to be a bit of re-orientation of the centre section so that the oil dump is facing downwards, and not upwards though.
Edited by Dale FZ1
https://www.sau.com.au/forums/topic/212634-garrett-to4e/#findComment-3756913
Went for a drive in a RB20 with a 700HP turbo on it the other day, i was unimpressed, never been in a car that actually came off of boost during a gear change and had to build up boost again.T04e's are very, very outdated man, i personally would be going something more modern, the lag that thing is going to have is a joke. Each to their own i suppose.
https://www.sau.com.au/forums/topic/212634-garrett-to4e/#findComment-3758860
Innovative made me a custom T04 with an O trim and the rest built almost identical to a 3582R I am making 480whp on my GTS4 at 1.4 bar with very little lag but my car has a Stagea Rb25det in it... on my Rb20det with this same turbo I was making just shy of 420 due to weak injectors and fuel peaks and it wasnt very laggy at all...
I would say get a hybrid built I payed 980 bucks plus shipping 2 years ago... and its ball bearing...
Edited by dwest
https://www.sau.com.au/forums/topic/212634-garrett-to4e/#findComment-3759081
    • He is around but doesn’t really do automotive stuff anymore, mainly does commercial work now
    • Shortly after I do the usual full exhaust/ fmic/fuel pump/ R33 turbo and still get flogged at the lights by i30Ns
    • Is Chris from Craved Coatings still around? He is an ex SAU guy and did great powder coating (back in the day at least)
    • Bumping this thread yet again, has anyone ever tried putting yet another vacuum regulating valve on the hose that goes between the turbo inlet? Something local owners have mentioned is the Radium breather pipes de-restrict the valve cover but it actually produces an undesirable outcome in practice, way too much air is sucked out of the crankcase and a ton of oil comes with it as well. As far as I can tell the PCV diaphragm in these modern euro wet sump performance engines is active during boost as well, there's just a check valve to block boost from entering the valve cover and crankcase as there's no inherent check valve function in these diaphragm-type valves. Hopefully I'll be able to try some of this out soon. The Volvo XC90 4.4 V8 has a nice external version of these things.
    • So when will the Samsonas, twin scroll turbo setup on go?
