  • Replies 45
it had being checkout i can also give you the number of the turbo spec thats checked it just whistles while it whines down like when you turn the car off no shaft play no smoke worked fine for me only reason for selling is a have a whole new engine trasplant happeing
I believe that relocation kit went up on eBay, and I have won it... but he is not replying to me on eBay. I've been requesting for postage cost & his bank details.
Have made several attempts to message him as well, no reply. Although it says please contact within 24hrs, I did it within 1 hour of winning the auction, and a message everyday.
Link: http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...sid=p2759.l1259
i was watching that on ebay! fark so it was u! haha
doesn't the nick ring a bell? ahhaha
But seriously, I think he is doing a runner.... coz its went so cheap on eBay...
have u paid? well i was like WTF I WILL PAY MORE wen i saw it but hey life is like that. yea man this guy/girl/tranny :S better own up ...better yet just report them to ebay :D hahahai did that once with a person who never got back to me and *wham* got them item on express in a dasy or 2.
no runner thankyou
all item have being posted soory for the delay on ebay but havent being on the computer pleanum has being posted as well and so will oil kit as soon as the money comes thru sorry for the delay
no runner thankyou
Hi mate,
I have requested for the payment total on eBay and your bank account details as it is not provided on eBay. Once I receive your bank details I will direct deposit the money straight away.
Cheers,
Johnny
Expect to wait a month to receive your parts if at all. I felt like i was being scammed. This bloke doesnt answer calls or PMs. Watch out.
I'm still waiting :)
Messaged him on eBay no reply, SMSed his phone same thing....
i have tryed to deal with this guy & i stopped as he`s useless will not return pm`s then say`s what happening take 3 week`s to do NOTHING ,so GUY GIVE HIM A MISS waste of space i think it was early april i started sent so many pm`s nothing back .sorry to see these people get on here.cheer`s chuckie.
    • Gas MIG for learning, I was able to weld up some nice 1.6mm tubs so you can do thin stuff easily enough. Then moved on to thick caliper adaptor brackets with the same machine, all good.  Arc/Stick is great for dirty garden work etc, but Gas MIG for starting on car stuff.  Jump on the NCR FB page and search ATP Tubs or GKTech caliper adaptors for pics/info. I'm no pro but it wasn't hard to learn. Be willing to grind and go again though if it's cold etc.
    • That's not a bushing!
    • Oh and I got myself a grandpa spec dash mat.
    • Ok, so first round of maintenance done. I didn't get much history with the car but I know it was well looked after. That isn't enough for me though, so ...  I had to do the oil filter housing gasket. It was leaking a lot, and also as part of that I did the anti-return valve and the VANOS oil line (from HEL).  But, then I got hit with the while-ya-in-there's. Did both accessory and A/C belts, tensioners and pulley. The accessory belt that came off had a huge hole in it, like somebody hung it up with a nail. The pulley and tensioners seem ok, so I'll keep those just in case. I did water pump and pump pulley. The water pump had a small bit of play so timing was good.  I also did fan clutch. I don't know how to test the old one but between the water pump and the fan clutch the car is running a little bit cooler (not much ~2 - 3 degrees maybe) so good result. Unfortunately the thermostat and housing didn't turn up in time so I'll shelve those. I have no concerns at all on the current ones.  Then I spent what seemed like 40 days and 40 nights bleeding the air from the cooling system. She also got new air filter, fuel filter and did a Mobil 1 change with oil filter. Hilariously, not an hour after telling my wife how proud I was of myself to be going slowly and meticulously and making sure everything was torqued and nothing missing I went and started it without the oil filter in. The car complained immediately of no pressure and after only a few seconds I turned it off and discovered a shit tonne of oil on the driveway. Sigh. I've driven it since and thankfully doesn't seem to be any problems. AND THEN during the test drive a ratchet extension fell into the battery area in the boot and JAMMED right next to the positive terminal and the car body. Like, just touching it made sparks and it was jammed in there. So, almost killed the engine and then almost burned the car to a crisp. Good start. This was the rails under the splash guards. So stoked, she's straight as and super clean. No rust anywhere. There was a heap of caked dirt that I removed but otherwise looked great. All 4 jacking points are perfect.   Next I want to service the gearbox. Sometimes it's a little reluctant to shift up and I'm hoping a fluid change will sort it. I also have 4 new rear subframe bushes. They're as big as a toddler. I'm renting a tool to help put them in. I can't wait for this because its a bit crashy back there at the moment.
    • Remember when those donkeys kept using freedom units and smashed that satellite to bits on the moon? NASA has their brain switched on and uses the metric system.
