Hi all,
Just wanted to know if anyone has done an install of the new just jap cooling pro stealth fmic kits onto their R34 GT-T?
Also,
1. Did you have to cut away any metal?
2. Does the air-con fan/compressor get in the way of the core? I know the horns need to be moved, but what of the aircon?
And yes, I've searched a lot for these answers but have only come up with info for an R33 and for generic kits.
Thanks in advance,
Suj
https://www.sau.com.au/forums/topic/212656-r34-fmic-installs/
dont buy the kit man its f*kn shit, gets in the way of a aftermarket bonnet, you have to get rid of your engine bay cover, yes there is cutting (under batt tray) and yes the fan gets in the way.
shit kit buy something else
but it is cheap.........and thats why i bought it -_____-" replacing soon thoughh =]
Edited by R34NRG
Actually this kit is the new stealth one they have just released...it uses the standard inlet and outlet of the stock SMIC. Its similar to the Blitz LM and ARC kits. No cutting under the battery tray or anything.
Relocation of the Aibag crash sensor may be required, it sits nicely about 10cm below it's current location, just drill a new mount hole for it. Horns can be relocated to the side of the bumper support and rewired in. Really would be good if it was a full 3" inlet and outlet as well.
LoL
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
