Hi all,
There's a wealth of info in the rb30 thread - but it would be nice to have a thread about what pistons everyone's used - CR, head gasket used for CR, forged or not, brand, pin heights etc etc.
I saw one guy in the rb30 hybrid upgrade dyno results thread is using 10:1 pistons on a turbo rb30.
Please post away your piston specs - I'm in the process of doing up a rb30 so would appreciate any input!
Cheers
https://www.sau.com.au/forums/topic/212676-pistons-for-your-rb30/
I have 8.3:1 CR, Stock pistons, OEM RB26 Head gasket
How is it off boost?
Aries Pistons, probably can go better but never had a problem and made massive power..
CP's - look on Ebay US, they're cheap as!
Hi there,
Just was checking out Ebay US but couldn't find CP's for Rb30's - do you have a link?
Cheers
I only found the MAHLE RB30 pistons
MAHLE RB30DET
Also these cheap Rods...
Rods
Seems very cheap...just over $1k delivered for forged bottom end parts (how strong thats another question...assuming its at least better then a standard rebuild).
Would those rods suit those pistons ?
Edited by KISIN
good i think? bit hard to say cause i dont have anything to compare too apart from the 25 which this motor eats for breakfast off boost!
how would you expect it to feel?
Hard to say on the net, sluggish i guess is the closest word
....havent been on the forum for long so sorry if this has been covered a billion times.
But when doing the 25/6 head swap on the 30 bottom end doesnt it lower the compression a fair bit due to chamber size (i think i read that sumwhere).
Anyways, how much does it lower it, say if you have 9.5:1 CR with a rb30et, wat would comp be if you just did the str8 up 25 head swap and didnt touch the bottom end?
Thanks
Jon
Edited by VKYOOT
we just got a new set of mahle 40 thou oversize forged pistons from hi octane. They look very schmick!
Will be the first set of pistons used in one of the many rb30 builds weve done that hasnt come from CP.
Judging by the specs on the piston box i imagine it will net a comp ratio of about 8.2:1, same as the flat tops CP provide for the conversion.
Edited by r33_racer
Thanks
Jon
About 8.8 at a guess
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
